Check Ya Later 2000 25 OL SST >
Old 06-09-2020 | 05:34 PM
thisistank's Avatar
Originally Posted by bdavidt
I’m new to stern drive boat. When runnin WOT where do you want the drive trim at? I know not fully down, but 3/4 down? 1/2? Per the gauge.
Getting on plane I’m putting trim tabs all the way down, still having some trouble gettin up.
Your prop must be seriously wrong. You shouldn't need much if any tab to get on plane. Drive tucked in, tabs neutral, keep it under 3500 rpm, roll on easy and it should jump right up. Once it rolls over kick the drive out "a bit" and you'll feel the boat loosen up. Play with the drive setting and feel the boat. If it feels "wet" and nose heavy, kick the drive out a little more. If it starts to hop, you've gone too far. You get into rougher water and start airing it out, you sholdn't be nose up too much when you come out of the water. I really didn't use the tabs in our Baja much at all unless I was in some big water and needed to keep the bow down.
I pulled the 454 out and dropped a worked and chilled 525SC putting out about 650 hp and it was hitting about 80. Started getting a little sketchy.
thisistank is offline
Old 06-10-2020 | 06:39 AM
resurrected's Avatar
Originally Posted by apex svt
I agree with the boat being able to run 60’s. We had an 25 OL 496ho, would go 61-62 all day 63-64 lightened up (Non-GPS). That was with a dah cupped mirage plus 23p.
Those boats like a little chop to get some air under the hull.
5# Procharger kit picked up 10mph 75mph was the best we saw with a 28p 4 blade mirage on that setup.
pre blower
Post blower
White knuckle ride!
resurrected is offline
Old 06-15-2020 | 02:44 PM
Any updates on the new ride?
Eddienel is offline
Old 06-15-2020 | 06:47 PM
prop wise no. Local guy didn’t have any I could test. Gonna go through bblades rental program after I get some more info to give them.
I did change impeller and housing, all fluids and filters.
bdavidt is offline
Old 06-17-2020 | 09:37 AM
Was on water to get MPH and RPM to try different prop, and go figure mph gauge went out. Was still showing up to about 35 and wouldn’t go any more past that. So, I used a gps speedometer on phone and took video of that. Got about to 60 mph about 4600rpm. Any ideas where to check for mph gauge?
bdavidt is offline
Old 06-17-2020 | 03:18 PM
SUPERSTITIOUS's Avatar
Clogged pitot tube or pick up
SUPERSTITIOUS is offline
Old 07-01-2020 | 09:57 AM
Update to some of the issues:
Boat started to die upon initial startup and couldn't hold RPMs steady. Swapped IAC and Temp Sensor w/ little to no change. PITA to get started and maintain idle, once it gear it does fine at idle, but now it really struggles to get on plane if at all. Boat now hits about 2500 rpm trying to get up w/ backfires every 5-10 seconds. Swapped cap, rotor, plugs, wires and new gas no change. Pulled out of water yesterday to dig deeper into the issue.
I did notice the drive trim limit insert 'celery stick' was on opposite sides, guess that could explain the initial struggle to get out of water from the beginning.
bdavidt is offline
Old 07-07-2020 | 10:53 AM
Turns out fuel pressure is low, high as I could get it was 23 psi. Calls for 42 psi. Couldn't find any leaks, getting a fuel pump and hopefully have it resolved by the weekend.
bdavidt is offline
Old 07-22-2020 | 09:30 AM
Swapped fuel pump, and adjusted timing. Running good now, still kinda slow out of the hole w/ two people and full tank. Gave it a good wax and changed the boat name decal.
bdavidt is offline
Old 07-22-2020 | 09:32 AM
bdavidt is offline
