Alarm went off, Why?
I’ve worked on a handful of boats with impellers in decent shape that had bunch of impeller pieces blocking entrance to oil cooler. How does that happen ? Humans.
Not removing the pieces doing previous impeller replacements. As just noted above, exhaust manifolds and/or risers can be corroded enough internally they are not passing enough water. After checking all other things - impeller and housing, blockage at cooler, recirc pump impeller, bravo-itus hose fitting corrosion/restriction , and etc.....may be time to pop off risers to take a look see.
Any chance your boat was used in salt or brackish water ?
Sorry for the long time to update. So I changed the impeller and the thermostat (which was stuck closed) yesterday had the boat out all afternoon running at all kinds of speeds with no alarm sounding. On the way back in which is about a 45 minute ride in no wake zone, about 4 minutes from the dock the alarm went off (not a steady alarm, I would say one second then a three second pause) all the gauges read fine. Water temp all day never got above 175 most of the time it was around 150-160. Is it possible it could be a bad sensor somewhere giving a false alarm? So Frustrating
