1997 Baja outlaw stringers. >
Old 07-26-2020 | 12:15 AM
Default 1997 Baja outlaw stringers.
Hi I heard the Baja outlaw pre 2000 has stronger issues. I went and looked at one today with twin 454s at 300 original hours. I found a little crack wondering if I should be concerned. Thanks for the help he’s a photo
Svenny14 is offline
Old 07-26-2020 | 02:13 PM
I knew of a 1992 that had 0 issues up until it was stolen and they were cut to get the engine out, that was 2010. The boat has a blower on it since probably 1992 or 1993 with juice.
tmmii is offline
Old 08-09-2020 | 12:21 PM
Ask if you can turn the motor mount bolt that goes into the stringer top. If they don't tighten stringers rotted.
Tractionless is offline
Old 08-11-2020 | 10:26 AM
obnoxus's Avatar
Charter Member #1171
+1 to traction. My 1997 272 was bought new and was a trailer queen. Stored inside, never left in the water etc. My stringers still went bad by the motor mounts within 5 years of owning it. The bottom also blistered where it sat on the bunks of the trailer. That being said......The only reason I knew this was I swapped the 454 for a 502 and found, and repaired the stringer issue at the motor mounts. It was a very small section that was bad. And the only way I knew about the blisters was I .would jack it off the trailer to be able to wax the complete hull.
I want to live in a world where a chicken can cross the road and not have its motives questioned.
obnoxus is offline
