Beware Of Stuck Corsa Capt Call >
Old 11-14-2002 | 01:18 PM
baja bailey's Avatar
I was just wondering if these selenoids sticking can cause any problems to your engine? I dont have any type of silent choice on my H2X, but I have alot of friends that do... I have noticed my friends 35' Fountains sticking before. After a long cruise when I come off plane I have steam coming from my starboard side exhaust for a few seconds like garshev had said? I read an answer to this from Powerboats Teague on Tech that said it was normal due to the way the water is routed through the engine or exhaust?
baja bailey is offline
Old 11-14-2002 | 02:58 PM
Originally posted by Baja Daze
29 Outlaw,
I attribute more soot to less water.
Come to think of it, you're probably right but I was looking at it backwards.
WOW - imagine that
A case of less = more
BD - I run mine on the hose with the earmuffs on the drives. I also get tons of water coming out by the drive
29 OUTLAW is offline
Old 11-14-2002 | 03:28 PM
Charter Member #319
Get rid of all that bull **** and switch to CMI Dry Exhaust. You'll love it.
bajabob38 is offline
Old 11-14-2002 | 03:42 PM
Dock Holiday's Avatar
Charter Member #34
Bob,
I keep hearing that from others boaters. I think Tank has said the same. But doesn't it hurt your ears after a full day of running?
Mark
Dock Holiday is offline
Old 11-14-2002 | 04:31 PM
I would do it but I would also need an ECU re-cal. Whipple reports lean conditions on 496's when switching exhaust without performing an ECU re-cal.
Old 11-14-2002 | 08:11 PM
Charter Member #319
Originally posted by Dock Holiday
Bob,
Mark
No Dock it's music to my ears.
Old 11-14-2002 | 08:48 PM
Charter Member #34
The wife says get rid of the mufflers. Hell I might as well get rid of it all.
I just saw a dry setup that was pretty cool. The water exited inside the exhaust but was not a seperate tube. It is hard to explain. I believe CMI made the unit.
Guess this would not be that hard to do.
Do you get hassled by the law any Bob?
Old 11-15-2002 | 07:15 AM
CigDaze's Avatar
Thanks 29outlaw!...appreciate the info.
Dry exhaust would be great, but $. And believe it or not, I like having the captain's call...there are times when it is only appropriate to quiet things down a little.
CigDaze is offline
Old 11-15-2002 | 11:12 AM
Kentz
29/BD - thanks for the info. I too, have noticed my HO's steaming and having less water flow on the port sides. This was inherent with the older 454 mags also. It must be a merc "thing"
Old 11-15-2002 | 11:45 AM
Charter Member #319
No hassles where I boat ( knock on wood )MD. NJ.But I would check your local laws, is does sound sweet. I like how the wife says get rid of the mufflers, you got to love that!!!
