-   Baja (https://www.offshoreonly.com/forums/baja-31/)
-   -   Fuel tank access (https://www.offshoreonly.com/forums/baja/377957-fuel-tank-access.html)
SB 12-21-2022 05:58 AM
Some ski / wakeboard boats do use in tank fuel pump modules. I do not know the uscg requirements.
https://cimg1.ibsrv.net/gimg/www.off...b989bf2c2.jpeg
Joeyboost 12-21-2022 06:54 AM
Originally Posted by Wally (Post 4854009)
If you look at marine electric fuel pump setups, they are usually mounted close to the engine as possible.....most times with hard lines after the pump going to the engine. If the line breaks feeding the pump the check valve in the tank will stop flow and engine dies and no fuel spilled.......if the line feeding the motor on an in-tank pump setup breaks, then it will flood the bilge with gas. ...........big boom!
OK WELL THERES A VALID POINT!!! that makes complete sense! point taken, thank you!
Joeyboost 12-21-2022 06:58 AM
Awesome, I was thinking I needed to either pull the tank, have it professionally cleaned before welding or using a bulkhead fitting but I dont trust it wont leak in the floor and turn my boat into a bomb.
That goes into the filler neck? only thing about that is the return fuel line is long to get from the engine to the filler hose?
Joeyboost 12-21-2022 07:07 AM
Originally Posted by tgorbett (Post 4854024)
My 1996 272 had an extra fitting and I used it as a return. Just look under the back bench round access panel. The extra fitting had a pickup tube on it as well.
https://cimg1.ibsrv.net/gimg/www.off...9b9e95aaa.jpeg
https://cimg4.ibsrv.net/gimg/www.off...c6b0c19cd.jpeg
https://cimg0.ibsrv.net/gimg/www.off...7724197823.jpg
https://cimg2.ibsrv.net/gimg/www.off...191f8ce2aa.jpg
On your 272 the panel screws are clear as day, not so much on mine. I hope their not buried under caulk and bad things are lurking beneath the floor of this boat?
F-2 Speedy 12-21-2022 08:38 AM
I run the return from the regulator to the top of fuel filter head as per Whipples installation practice, three years and no issues
https://cimg9.ibsrv.net/gimg/www.off...8419b7db87.jpg
Joeyboost 12-21-2022 08:51 AM
So it just recirculates it right there and never makes it back to the tank. I assume you still run an inline fuel cooler because I would think your going to superheat the fuel like that alone?
BADASS setup!!!!
