Coming Soon
Houston Propeller has aquired the domain name Bajapropellers.com and we will be setting up our own little site,I will continue to work with Blake and will also be here on offshoreonly but ,I love the name and will let you know when its up and running.:cool:
Pretty COOL!!!!!!!!!!!!!!!!!:D :p ;) :cool: :eureka:
SWEEEEEEEET ;)
I will spread the word around here....
Tommy |
Darrin, are you limiting your services to baja customers for any particular reason? I am still waiting to see how doc holidays props worked out for him as I plan on doing some b1's 28p this spring.:drool: :drool: :cool: :cool:
YEP!
Originally posted by Dock Holiday Pretty COOL!!!!!!!!!!!!!!!!!:D :p ;) :cool: :eureka: |
darin:
that web site sounds awsome!!! i will be ready to send my prop to you in feb. i sent you am e-mail a few months ago. here is my bio: 29 outlaw 502 mag mpi. bravo I 21 pitch 3 blade mirage wot: 4900 rpm's 57 mph gps. i am going to install a k&n air cleaner in the next 2 weeks. should i go out and re-check readings prior to prop work?? i also will need some clean up work, there are nicks on all 3 blades. jc:D :D :D |
Originally posted by jcboats darin: that web site sounds awsome!!! i will be ready to send my prop to you in feb. i sent you am e-mail a few months ago. here is my bio: 29 outlaw 502 mag mpi. bravo I 21 pitch 3 blade mirage wot: 4900 rpm's 57 mph gps. i am going to install a k&n air cleaner in the next 2 weeks. should i go out and re-check readings prior to prop work?? i also will need some clean up work, there are nicks on all 3 blades. jc:D :D :D |
maybe
Originally posted by garshev Darrin, are you limiting your services to baja customers for any particular reason? I am still waiting to see how doc holidays props worked out for him as I plan on doing some b1's 28p this spring.:drool: :drool: :cool: :cool: |
lab now or later
Originally posted by Big E Hey JC - If you don't mind, let me know how your props turn out when you get them back from Darin. I was thinking about sending him mine just to get cleaned up. I am real interested to find out your results since we have the same boat (single 29 outlaw w/ 502 mag). Thanks - Eric |
| All times are GMT -5. The time now is 04:43 PM. |
