need help
I have 1991 240es 454 330hp but last year need some in sight on whats a good prop half out hole and great top end can any one help
I saw your running a 23, a mirage I presume... I'd try a 22 Bravo 1 four blade. I changed from a 23 three blade to a 22 four blade on my 272 and really like it. I lost a couple mph on top end, but out of the hole and mid range improved dramatically.
I tested everything on my old 24 and the 23 mirage + was the best
good advice
I would go with a 23 mirage and now is the time to buy ,before summer gets here,then it's worth gold:D 275.00 polished,hardware not included. also if want the prop labbed it would be 375.00 Darin
thanks guys
baja240
let us know when your ready ! Darin;)
HOUSTONPROP,I have the same boat (96) .We tube the kids alot
would that 3 blade mirage still work.I am currently running a 22 4 blade mach prop...:confused: :confused: |
23 mirage vs.mach 22 4 blade
Originally posted by Riverrunner HOUSTONPROP,I have the same boat (96) .We tube the kids alot would that 3 blade mirage still work.I am currently running a 22 4 blade mach prop...:confused: :confused: |
I have a 1997 240 with a 454 (stock). Presently, I am running a 24p four blade bravo. I also have a 23p mirage plus. I use the four blade almost all the time. Better midrange and start. The 23 p has a terrible midrange,but is about 3 mph faster. I have never tried a 22p four blade, maybe I need to try that. For over all performance the four blade is better on my boat.
| All times are GMT -5. The time now is 10:02 AM. |
