How fast is a 24 outlaw? >
Old 09-09-2003 | 08:17 AM
I have a 95 with a 454 mag efi that I rebuilt, new cam, exhaust, valves, etc. approximately 450 hp. I get 68 on gps.
FBRONCO is offline
Old 09-15-2003 | 12:45 PM
I HAVE A 93 24 OUTLAW 502MAG 21MIRAGE 62.4 GPS. IT IS ALSO FOR SALE. SEE IT ON THIS FORUM. HAS BEEN TOTALLY REDONE
PROMAN is offline
Old 09-15-2003 | 05:23 PM
AIRTIME
my 88 has 600hpat 5050rpm tq 620at5050 and I'm not happy , 74 mph with 50 to75 gallons of gas I raced p5 last yr I 'm going to try a2'' or 3'' shortie this winter buy one hope to break 80 then at 5400 rpm 625 hp tq 597
Old 09-15-2003 | 11:10 PM
Allan4
A-time...
I was thinking about trying that also. May try one this fall, I will post results.
I'd like more power, but by running P5 I am not going to add power. It is set up just right as it is....
Old 09-16-2003 | 07:10 AM
Default Allan 4
Hey Allan,
tried a 21 Rev 4 on my 24 Outlaw. What a difference, ran great, may need a 23 labbed. You were 100 % correct on the Rev 4 though. Tried all kinds of props & that seems to work best. I also replaced my cracked CMI headers with new & that probably also helped.
Thanks John
Johno is offline
Old 09-16-2003 | 09:28 PM
Allan4
Great news Johno, glad it helped.
I would love to try that 21rev4. If you are comfy with sending it up here for a few days, I would LOVE to try it out. I labbed my 23 and picked up little or no speed or revs. I really need to get a shot at a 21 to see what happens. I think it would help me pick up a little mph....maybe 1ish or 2ish at max.
I will load you up with freebie stuff if I can borrow that prop!!
If not, it's okay, I understand, just thought I would ask.
How many rev's are you pulling with the 21? What Power?
Thanks, glad I could help.
A4
Old 09-17-2003 | 08:48 PM
Default Allan
I am going out this weekend, 5 people & full tank with gear. I will really check it out better & have more info. I was just really pumped the last time I posted as I have have had real bad luck getting this motor combo sorted. Hopefully my luck will change
I plan on buying a 23 & getting Throttle up to Lab it for me. I will check RPM Sat, the mid range is awesome & and the boat pulls hard. Coming onto a plane is almost instant. Maybe a Bravo 22" 4 blade may also work?? That Rev has been the best I have tried. Motor is a HP 500 .30 over with Merlin intake 800 Holley, 139731 Crane cam+- 530 HP I guess??
I can ship it up to you, just let me play a little & we can compare results.
John
Johno is offline
Old 09-17-2003 | 09:52 PM
Allan4
Hey Johno, I bet you are a little less thatn 530hp, but that is a nice package you have. Very close to what I am running....same cam and ci's. You probably have over 550ftlbstq, that is why the midrage pull is killer. Mine pulls really hard....it actually pushes you into the seat.....even the big power guys like the accel of that boat and motor.
Sure man...take your time....it's your prop!!hahaha
We will be done for the season in about 4-5 weeks, so if we can't get together by then, that is fine, maybe we can do something for the spring.
Have fun, let me know how it goes and thanks for the offer.
A4
Old 09-19-2003 | 11:08 PM
baja2700
Default Speed
Allan
I have a 97 24ft Outlaw
I run an Hp 500 Carb engine with a 731 cam, merlin intake, gold roller rockers, Imco exhaust. runs a 23P mirage plus reworked to a 24p runs 73 mph on GPS at 5250 rpms. Spent 30 hours blueprinting the hull and it lists to port, does yours????I have to drop the port side tab 2 bars lower to run flat and it chine walks above 65mph like a big dog. It does have latham steering...any thoughts???
Old 09-21-2003 | 09:10 AM
AIRTIME
ALLEN 4 hey I run a 4 blade 26 bravo and had run a 25 mirage which I just sold, when I raise the drive 2'' . it will be 4 or 5 blades only if they make a rev 25p I would think that would be the prop?
