Originally posted by BRET Darrin, Sent oyu a pm. Your box is full. Empty please. Bret |
Re: HIGHER X DIM??
Originally posted by HOUSTONPROP RIC,I know its higher?? but I think a 1/2 maybe (not alot) I, would go with some Mirage plus converted to our ACCLERATOR PROPS. RIC, he mentioned he is running 28's not 26 pitch props. Give me a p.m. and I will call you we can PROP TALK:D |
Bret
I have a 2000 33 Outlaw I repowered with 500hp's that Rod worked over. I had 27 Mirage plus props that slipped horribly. Instead of waiting for the 27's to get labbed last summer I bought some labbed 26 Bravos and lost a solid 6 mph. Mercury Racing said not to run 4 blades on that boat and they were right. I shook more things loose in one weekend with the 4 blades than I ever shook loose in 2.5 years with the three. The 4 blades were awesome in holeshot and in turns you could lay the rub rail in the water but i could never lift the bow high enough to let her run and therefore the nose wanted to plow thru waves at the Ozarks. Darin is labbing my 27 and says hey can put the holeshot and handle in the three blades. They are on their way and I am anxious to try them. |
Bret
I was told that we have a 2" lower X than the newer 33's |
Ric,I still wished you would move to Texas and start working props with me:D You definitely know your stuff when it comes to boats and props.Have a great weekend.;) later Darin
Originally posted by outlawinil Hey Darin whats the latest on my 27's. They are going to have to be right on the money the first time because tweaking them means I'll be without them most of the boating season. |
my buddy has a 01 33 with efi's and mercury labbed 30'' bravos running 77.1 gps, when it had imco -2'' it ran 80.5 gps I would suggest labbed 30'sunless you run in shallow water, unless the 3 blades will get you on plane then I would say 27 mirage plus, the 02 and newer 33's won't budge with 3 blades the x is to high
The reason I say run in shallow water is becausethe thinned blades lose some strength , we found out the hard way the first time out
Thanks liquid.
Mine is a 98. I only ran it twice but it seemed like it wouldn't break loose with the bravos. Of course rhere was no chop either time. I'm going to put some seat time in it before I spend the money on mirages and have them labbed. If I can get the performance from the labbed bravos maybe I'll go that way. |
Originally posted by LIVING LOUD Hey Darin-Look forward to receiving my props --Hopefully by next Wed. Leaving Thurs. am heading south for pokerrun.. Allen P. |
| All times are GMT -5. The time now is 05:14 PM. |
