Re: speed on a 36 outlaw
525's 75-77,500's 73-75.
I am doing 74.8 on gps was wondering if that was right? thanks!!!!!!!!!!!!
I'll stand on my original #'s too :D :D :D jt |
I am in agreement with everyone with the added information. I believe the 99 is a bit slower. I only ran with a GPS a few times but my best was 75.1 MPH and I do run in salt water. I think there may be a little more there as I do hit the rev limiters. I have been able to hit 80 on the Speedo which I enjoy when I have newbies onboard. I don't educate them on the difference between GPS and Speedo :) Bigwavz...are you running a Whipple?
what kind of speed are you guys getting with a 36 outlaw? And what kind of prop?
Fresh water, 5200 RPM the best we have seen on GPS is 74 MPH. It will run 71 to 72 almost any time except in flat water. The boat is really heavy, we have almost every option including A/C, plus a ton of accessories, all my wife's stuff, fuel + people and stuff. When you factor in the weight, handing, ride, room (cockpit & cuddy) and safety it is not too bad for a true deep vee boat! Hope this helps! |
Originally Posted by Bigwavz
I would say around 70. The 36 is a heavy boat. A 33 will run around 72-73 with HP500's
I just bought a 36 so in a few months i'll tell you how fast it will go with around 1500 total HP. |
Hey Drill It do you ever run around the Lake St. Clair area? I would like to hear those motors,they must have some serious thump to them! :woohoo:
I do most of my boating in Port Huron but I do get down that way a few times a year. Do you also have a 36?
Drill It |
I've got a 33'.I thought you were from this area,how did you get hooked up with Lingenfelter?You don't see too many people running his stuff.How do they run? Do they idle good around the docks? Can you tape record the way they sound so I can listen to them in the shower in the morning. :D
1999 36' HP 500 EFI's with extension boxes...
26P Labbed Bravo 1's [email protected] to date 23P Mirage plus [email protected] to date Both were with full load of fuel and 2 peeps Steve |
| All times are GMT -5. The time now is 08:40 AM. |
