MPH for 25 Outlaw >
MPH for 25 Outlaw
MPH for 25 Outlaw
Old 03-01-2002 | 03:24 PM
  #31
29Fever
Gotta have it,
I really doubt you're going to see 72 with a 26". It may struggle to get on plane. If it does, I would guess you would max out around 4700-4800 rpm. It sounds like you've got good speeds already for a stock setup. Make sure to post your results.
Old 03-01-2002 | 06:44 PM
  #32
liquid asset's Avatar
My 24 has a 26'' and planes quicker than my mirage 23, and does not blow otut and does it with no tabs, props are funny, you never know until you try
liquid asset is offline
Old 03-01-2002 | 09:51 PM
  #33
Visual contact
Default Baja speed
I have 2001 25 outlaw 454 Mag. I can run 65 all day. I can inch 67 or 68 on perfect water. All I have done to mine is installed gill offshore exhaust. It raised my rpm,s about 225. I'm running a 23 prop on now and going to change to a 25 just to see!!
Old 03-02-2002 | 12:03 PM
  #34
garshev's Avatar
Default 25 outlaw speed
There is considerable differences between the 24 and the 25.
1 foot longer,4 inches wider, 750 pounds heavier, notched transom, notched spray rails, just for starters. I owned a 98 25
with a 502 mag that ran 66 mph on gps all day long and mine was one of the fastest around here in the north country. With
a 496/375 I would expect to see 62 to 63 with a full tank and load. just my .02
garshev is offline
Old 03-02-2002 | 03:02 PM
  #35
GARSHEV, you are wrong in to ways ,the 25 is only 250 lbs heavier and 2'' wider
Old 03-03-2002 | 12:14 PM
  #36
garshev's Avatar
OOPS. I goofed again but why quibble about 2 inches of beam
(at least thats what my wife tells me).The 96 brochure lists the 24 as weighing 4000# while the newer brochures lists the 25 at 4750# seems like 750 # to me.
garshev is offline
Old 03-03-2002 | 12:43 PM
  #37
I own a 1997 24 outlaw that weighs 4500 dry I wouldn't argue if it was'nt a fact , trust me I would kill to weigh 4,000 it would be a whole lot easier to get 70 mph ( check the archives for a 1998 24 se on www.bajamarine.com)
Old 03-03-2002 | 10:36 PM
  #38
yyyyyyeeeeeeeehhhhhhhhhhhhhaaaaaaaaaaaaaa
Old 03-03-2002 | 10:38 PM
  #39
wrong one now then yyyyyeeeeeeehhhhhhhhhhhhhhaaaaaaaaa
Old 03-04-2002 | 11:31 PM
  #40
FEVER, no I wish , I just have a 24 outlaw, but I just got it this winter so I guess it'll do for this season
Attached Thumbnails MPH for 25 Outlaw-thursday-february-21-2002-format-change-jpeg-high-quality-copy-1-.jpg
