-   Baja (https://www.offshoreonly.com/forums/baja-31/)
-   -   Help! All Outlaw Owners 29'-33' Twins (https://www.offshoreonly.com/forums/baja/99447-help-all-outlaw-owners-29-33-twins.html)
32 caliber 03-30-2005 07:32 AM
Ok, I have seen some using Bravo 1, and some using Hydro's. Has anyone actually tried both out on their boat ? I bought a 32 Caliber, Liquid Asset suggested using Hydro's, I did buy a set. Where I live it is still to cold to try it out. I would just like to hear from someone that has actually tried both brands out on their boat, and why,what the difference was. I know the Hydro's lift stern and Bravo's lift bow, which one really is the better application? If its the Hydro's then why aren't everyone using them and the same could be said for the Bravo's. Anyone ?????
liquid asset 03-30-2005 03:15 PM
Re: Help! All Outlaw Owners 29'-33' Twins
The hydos ran my boat to 71 gps with stock 502's, but they will not work on 02 and up 29's or 33's with the raised X, They will not get on plane . I never messed with mine b cause it was to perfect to f with
32 caliber 03-30-2005 03:21 PM
Liguid, I took your advise and bought the Hydro's, I havent tried them yet because of the temp here, but I run across some decent prices on bravos1 at times and it starts to make me think about it...I think I need to go see a doctor !!! My wife says I have a prop fetish !
garshev 03-30-2005 06:27 PM
Jeez I hate to ruin your fun, but you really should be running mirage plus's. They are definitely faster and unless you are running shorty drives or have a non-factory x dimension will work better than either a bravo or hydro. :p :p :p :evilb: :evilb: :evilb: every blade you add slows you down. :( :( :(
32 caliber 03-30-2005 07:43 PM
I know the Mirage plus would get me a bit more speed, but how often are you really running wide open ? I'm not racing anyone, and Lake Michigan is a bit rough, so 4 blades for slow plane speeds and cruising really works out better for my situation.
Johno 03-30-2005 09:46 PM
Not entirely true, the technology & design has come along way in the last 10 years. Call Throttle Up Propellers & they will give you all the info you need. I was running Mirages until last week, prop tested with Throttle up & guess what? We got a 2mph faster on 4 bladed prop, killer holeshot & mid-range. When all is said & done I should see a atleast a 4mph increase with that extra blade. Every boat is different.
I have a set of 25" pitch Mirages in new condition for sale.
Take a look at the race boats, 3,4,5 & 6 blade props.
More blades don't necessarily slow you down.
32 caliber 03-31-2005 08:02 AM
Hey Johno, what size boat ? What props and pitch did you go with? What size engines?
garshev 03-31-2005 07:05 PM
What kind of boat are you running? Older baja's ran very conservative x dimensions and were actually designed for the 3 blade mirages. True the race boats are running 4 and 5 blades but they have stepped hulls and x dimensions at the moon. They need the extra blades to reduce slip caused by the steps and high x. :p :p :p :argue: :argue:
32 caliber 03-31-2005 07:20 PM
I have a 1995, 32' Caliber, twin 454/385hp.
outlawinil 03-31-2005 09:58 PM
I have a 2000 33 Outlaw and Mercury Racing said no way to 4 blades on that boat. I tried anyway and sold the props. Bravo 1's raised the stern and not the bow and therefore slowed me down considerably. Ride suffered too
