pro form
Old 01-29-2012 | 07:37 PM
  #31
aquaforce's Avatar
Originally Posted by adk61
if you are planning on using cometic gaskets, have your builder prep the decks to 50 RA (roughing average) this is the standard for cometic gaskets... also install them dry, as they have a viton sealer applied to the surface of the gasket (self sealing) and any additional sealer will interfere with the gaskets ability to seal... if your blocks were previously o-rung, you cannot use cometic gaskets... make sure of this before installation... use engine manufacturer specs for torque...
nice chatting, hope I was able to help...
Alan Kranczoch, AKRacing...
Thanks for the time to chat with me. Your perspectives helped to validate some things that I wondered about and your advice seems sound. I hated to spend more coin but I believe your right with the exhaust valves. It is the better decision to run the Inconels'. I was going to build on the cheap but I don't want a blow up story.
I got to find more pocket change.
aquaforce is offline
Old 01-29-2012 | 07:47 PM
  #32
glad I could help...
adk61 is offline
