Jim Darr names
Old 01-10-2015 | 09:30 AM
  #741
if it,s fact post up the dyno sheets.i for one would love to see them,espically the a/f ratio.
mike tkach is offline
Old 01-10-2015 | 10:35 PM
  #742
They posted the sheets on this thread on PBN after others asked to see the Dyno sheets...
http://www.po werbo atna tion.com/bilge/2274-55-mti-56.html#post24161
Copy and paste in your browser without the spaces since OSO blocks PBN or go to the 55 MTI thread on PBN page 56 post #1111.
Plowtownmissile is offline
Old 01-10-2015 | 11:10 PM
  #743
WeaponX's Avatar
It's a heartbreaker and a wife taker type of Power sure you want to see??. And this is on 7.2 psi
[IMG][/IMG]
H.P.Mafia style.
WeaponX is offline
Old 01-10-2015 | 11:40 PM
  #744
Such a shame Jimbo is such a douche and ruined his reputation... Hell, it goes back past the buddy00 and wiggler days
endeavor1 is offline
Old 01-10-2015 | 11:51 PM
  #745
WeaponX's Avatar
It is a GIANT shame. He has to live with all of this and I know it has to bother him. It does me.
Cant change the past.
WeaponX is offline
Old 01-11-2015 | 07:24 AM
  #746
jeff32's Avatar
Ok, been on oso for 10-11 years, i see once in a while a couple allusion to jim darr, still don t know what he did and how do you know its him when he changed names too many times according to the read... So, whats the long story short?
jeff32 is offline
Old 01-11-2015 | 08:07 AM
  #747
those engines won,t live long in the boat with an a/f ratio of 12/1.dyno hero numbers but not realistic in boat numbers.you do plenty of this type engines and you know what i am saying weapon x.also you say 7 lbs boost but no boost data on the sheet?if it sounds to good to be true it usually is!in any event they should still make decent power with a safe tune.
Old 01-11-2015 | 08:19 AM
  #748
buy the way jim,don,t bother sending me a pm threatening to come to my place to kick my ass because i don,t get excited from idle threats!
Old 01-11-2015 | 11:52 AM
  #749
Mike what would you like to see for AFR on this motor? The egt's look good with timing at 31.
Bawana is offline
Old 01-11-2015 | 06:05 PM
  #750
yes they do look good,to good.with a roots blower,7.2 lbs boost something does not add up.imo,r roots deal with 12-1 afr will create so much heat in the combustion chamber it will start pre ignition and then it,s game over.it will work for a short run but if you leg it out it,s gonna burn down.just for clarification i run my whippled 588s at 10.5-1 afr at wot.without meth injection i don,t know how that engine can produce that hp level on pump gas with those numbers.id love to put one of those engines on the dyno i use.il bet my last dollar the results will not be so impressive.
