-   Black Thunder (https://www.offshoreonly.com/forums/black-thunder-109/)
-   -   Optimal running temp for 500 efi (https://www.offshoreonly.com/forums/black-thunder/220525-optimal-running-temp-500-efi.html)
jus490 11-25-2009 05:27 PM
2 Attachment(s)
Finally got some time to toy with the new BT and have a couple of questions? number one is what temp is right for a 500efi I took it out and ran it and one motor was running around 180 and one was running around 150 so I took the thermostat out of the hotter motor and it is a 140. Im guessing it is just shot from sitting but am curious if that is the proper stat. number two is there are three acc. switches on the dash no. 1 does the silent choice but I cant seem to figure out what the other two are for. Has anyone ever tried to get a wiring diagram from BT. any info would be greatly appreciated, thanks, JustinAttachment 402871
Attachment 402872
fglightning 11-25-2009 07:04 PM
Justin-
Boat looks great!!! About time you posts some pics!!! You also may want to post this in General Discussion (you may get more info about your 500's)
endeavor1 11-26-2009 12:15 PM
Nice ride. The three switches on the dash control silent choice, compass on/off and the third on my dash is a dummy. As far as temps go, mine run at 150 all day. Never higher or lower. Bobs in and out of the factory right now but I ll be up to see him next week. What diagram do you need?
Chris
BDARCHER 11-26-2009 05:35 PM
NICE BOAT. Switch might be the power point. Higher temp could be weak water pump impeller.
Bobby
DrydenPERF 11-26-2009 06:37 PM
Bobby
Im with Bobby on this one ,change the impellor
Happy turkey day Bdarcher and check your email :lolhit::party-smiley-004:
jus490 11-26-2009 07:14 PM
thanks for the replies. The first thing I did when we picked boat up was change the impellers and the motor that runs hotter did have a very chewed impeller so I am wondering if some of the rubber is stuck somewhere but on all the other boats I have dealt with the first place it gets stuck is the thermostat housing but when I took that apart I found nothing I am going to check the lower hoses but I need a smaller guy to get down there as I dont quite fit. as far as a wiring diagram I am looking for a diagram of the gauges/ switches because I have some lights and thing that I would like to wire in.
Brad Zastrow 11-26-2009 11:17 PM
I see RunninHOtRacing is back on the board. Sending private emails spreading his wisdom.
BDARCHER 11-27-2009 05:16 PM
What EMAIL
BDARCHER 11-27-2009 11:18 PM
[QUOTE=Brad Zastrow;2997095]I see RunninHOtRacing is back on the board. :chill-pill:
Its about time Runnin comes back. This place is kinda boring lately. He livined OSO up. Sorry for hijacking JUS490
endeavor1 11-28-2009 06:01 PM
Runnin hot is hilarious. I ll post some pics of next weeks Black Thunder/Ateco engine pull. Sorry to stir the pot. Brad PM me if you can help mediate this problem.
endeavor1 11-28-2009 06:05 PM
JUS490. sorry about being groggy on the phone. Just woke up. I spoke to Bob, if you have a fax, we can send you a schematic or call me and i can tell you what to tie in to.
endeavor1 11-28-2009 06:06 PM
Bobby, what is the plan for your motors this winter. Keep us informed of what mods you do. Best of luck and good hunting
BDARCHER 11-29-2009 08:34 AM
I still havent pulled motors. Ill probley tear them down and have BB&T do machine work and build myself. Im still not sure about mods any suggestions , but would still like to have alum heads. Im a littled worried about XRs.
Thanks Bobby
BDARCHER 12-05-2009 07:18 PM
Lets see those pics of the pull, and get Runnin back.:drink:
Bobby
