What props on 460?
What year is the boat? The hulls varied slightly from year to year. 32's seem a bit much in my opinion. What prochargers and how much boost? What props are currently on it?
What is your speed and rpm now your probably somewhere around 650 hp I'd guess assuming heads are stock and so on do you know if the ecms where reprogrammed these boats run high slip numbers you have to harness it best way is more tip cup and run the biggest diameter you can look at all props
New boat to me. Not sure if the ecm's were reprogrammed or not. Ran the boat briefly last week and ran 68 mph and hit the rev limiter so I'm guessing the 28's aren't tall enough
