Go Back  Offshoreonly.com > Owners Forum > Black Thunder
43 Flat Deck AC unit... >
Old 02-14-2021 | 09:22 AM
Default 43 Flat Deck AC unit...
Can anyone tell me or show pics of how their AC unit is hooked up. I'm looking at a 43 and it seems as if the AC unit was partially installed. Curious where the water pump goes and where the water source comes from. Right now it sits in the closet just inside the cabin on the starboard side. Thermostat is installed and venting is there as well, I believe the water exit is plumb, just no water inlet. Looks like there is a through haul fitting in the floor of the closet but the supply line was ran to the bilge and possible going to be tapped into one of the strainers.
s022mag is offline
Old 02-14-2021 | 02:41 PM
F-2 Speedy's Avatar
Endevor1 Chris has a 43 BT, Im sure he'll see this
F-2 Speedy is offline
Old 02-14-2021 | 03:47 PM
Supply line is a thru hull ball valve fitting usually right under the AC unit. The pump is connected to this supply line then to the AC. The dump is a thru hull fitting horizontally mounted above the waterline. No pix right now of mine but after 21 years and lots of use, my AC water pump finally gave up the last time out in 2020. We use the heck out of it during summer as a nice escape from hot days. The BTs I’ve owned were equipped with CruiseAir systems. Pretty simple and easy to maintain.
endeavor1 is offline
Old 02-15-2021 | 09:28 PM
Where are your vents and returns? This one looks to be vented in the step, and the return is a vent in the door. They seem awfully close to each other and far from the V berth area.
s022mag is offline
Old 02-16-2021 | 08:12 AM
Return is in the access door. One Vent is above the TV/sink, other is in v berth.
Old 02-21-2021 | 11:20 AM
Do you have any pics of the vent in the v berth area, and any idea how the ducting gets up that way?
s022mag is offline
Old 02-23-2021 | 09:39 AM
ducting runs behind TV pictured above and is routed thru the top of the cabinets pictured here on the starboard side. The vent is round diffuser mounted on V Berth bulkhead/locker.
Old 02-23-2021 | 09:56 AM
IMHO pulling off the strainer in the bilge would be the better option for a supply line. Better chance of not loosing your pump prime and no need for an additional strainer....
jriggs is offline
