Go Back  Offshoreonly.com > Owners Forum > Checkmate
What Prop?? >
What Prop??
What Prop??
Old 09-09-2006 | 03:45 PM
Vinny P's Avatar
I hate the winter!!
Default Re: What Prop??
Rob,
I think that will work fine. Take a look at the #'s I had in post #10. You may get an idea of what to expect by using the #'s of my stock 454 magnum with a labbed 26" Bravo. Just allow for 90 more hp and I think you will be at your target rpm. Our hulls are identical, the data should be good.
Vinny
Vinny P is offline
Old 09-09-2006 | 06:32 PM
Thanks for the responses. I'll let you guys know how it all works out. First things first, I need to get the engine back in and add on some steering. I then plan on rebuilding the drive. I have owned this boat for 15 years and haven't had any misfortune with the drive as of yet.
Corbs is offline
Old 09-11-2006 | 05:47 PM
I need to try a 26 bravo 1 labbed on my 280, I was bumping the Rev limiter this pasted weekend in cooler temps. I really think my 500 efi can spin a 26 lab and gain some speed in the process.
Magic Medicine is offline
Old 09-11-2006 | 08:28 PM
RJBBC's Avatar
Registered User
Magic,
What prop are you running now? What is the rev limiter set at?
Rob
RJBBC is offline
Old 09-12-2006 | 03:13 PM
Originally Posted by RJBBC
Magic,
Rob
I am running a worked 24 Bravo, not sure what is done to the prop it was on the boat when I bought it. I think that the REV limiter comes in at about 5250 rpm. If I keep the boat, I am going to have the ECU reprogramed to lean it out on the bottom end, it is really rich at idle. I would also like to raise the REV limiter.
Old 10-05-2006 | 11:33 AM
EYEBURN's Avatar
Fast Willy,
howd the testing go? did you try some props......
EYEBURN is offline
Old 06-01-2007 | 07:56 AM
It's been a long road to acheiving what I expected. The boat ran good last year but had a rear main seal leak. So this year May of 07 we finally got her running good. We ran a 23 3 blade & it ran 71 mph on GPS. So I now just picked up a 26 4 blade & will give it a try this weekend 6-2-07. I'm just looking to get alot of trouble free hrs. run on the boat, but will occasionally push it to the limit. This weekend we are going to give it a good run down the ocean from Indian river inlet De, to OC, Md inlet. Finally going to let it stretch her legs.
Fast Willy is offline
Old 06-02-2007 | 01:31 AM
HiPerf2000's Avatar
the 253 hull likes the hydro prop. i ran a 27 hydro on my 97 253 with 560+ hp.
HiPerf2000 is offline
Old 06-15-2007 | 06:32 AM
Magic, does your cousin still have the 27 Hydro for sale? My new 540 made 610 H.P. and needs to be propped for 5700-5800 RPM. My boat is a 1991 25' Convincor with the narrow hull. Will that prop work for my application?
Corbs is offline
Old 06-15-2007 | 07:54 PM
Originally Posted by wild willy
corbs, i have the 27 hydro prop that magics cousin had. it is in excellent shape. if you need it contact me . i will sell it for what i paid him for it. 300.00 i sold my boat before i got to try it. bill
The prop is primo. Contact Wild Willy he bought it from my cuz last fall. Should work on your boat.
