Go Back  Offshoreonly.com > Owners Forum > Checkmate
mirage plus prop >
mirage plus prop
mirage plus prop
Old 03-21-2002 | 12:45 PM
Default mirage plus prop
would a 253 convincor be faster with a 3 blade?
looking for the best top speed .
currently run a bravo 1 ,4 blade---joe
duster340 is offline
Old 03-21-2002 | 01:53 PM
Default prop
we need to know more!! what year boat, what motor?the 3 blade mite be a little faster on top end, but you will be happier with a 4 blade hydromotive on your checkmate hull. most of their set-ups us a high x-deminison!good for speed! hope this helps !! bill
wild willy is offline
Old 03-21-2002 | 06:56 PM
mxz800's Avatar
what does the 4 blade hydro do that makes it so much better i think i am seeing high mph for my setup just curious 99 259 7.4 mag 385 hp have seen 67 on gps light load always see 65 speedo reads 70-75 currently using 23 mirage plus stock prop no lab running right a 5000 5100 on a good day
mxz800 is offline
Old 03-21-2002 | 08:32 PM
mpally's Avatar
The best way to find out is to do some testing. I think we all found out that CM played with the x-dimension so certain props work better on certain years and models. We run a 23 Mirage+ and I really like the way it handles with the Mirage+. Others can't get on plane with the 23 Mirage+. Either just do some testing and see how the props respond to your hull.
mpally is offline
Old 03-22-2002 | 06:34 AM
Default props
mx800, the hydromotive 4 blade makes our boats run more level ! it gives more transom lift where as the bravo and the mirage plus give more bow lift.if your hull likes the 3 blade mirage better, you will probally not gain any speed with the 4 blades, but you will like the better handleing ,especiality if you pull skiers or boat in rough water.you will find that everyone likes different props!us speed freakes are always searching for a little more!!! happy boating!!! BILL
Old 03-22-2002 | 02:55 PM
1997 checkmate 253,mercruiser 525sc,26 pitch
bravo one,boat runs 76 on gps.needs very little
trim-about 3 on my mechanical indicator,just wondering
if it is worth trying a 27 pitch mirage plus?. the boat
has a notched transom. rpm is at 5350.-------joe
Old 03-23-2002 | 09:41 AM
Default props
i don't think you can use the 3 blade mirage ,because of the high x-diminison that checkmate uses on their hulls. i couldn't on my 270 with 500hp the prop blew out real bad when comming onto plane!! i do think you would see more mph with a hydromotive prop! i just had one done for me. there are some other checkmate owners on the board that have seen improvements as for as speed and better handling from the 4 blade hydro prop. call tom at hydromotive 330-425-4266 he is very helpfull and will tell you what will work best for your setup. good luck and post feedback so others will benifit here!!! bill
Old 03-23-2002 | 02:51 PM
mxz800's Avatar
hey wild willy maybe we can compare our x-dim on our 270s my boat uses three blade mirage plus and never blows out coming on plane with out using tabs. i come up onplane smoothly but not wide open.99 270 454 385hp maybe because you guys have more power than me?? for now
mxz800 is offline
Old 03-24-2002 | 10:18 AM
st
Does anybody have a 23" Mirage they want to sell?
Or trade for a 23" Mirage +?
Let me know- SCT
Home: (419) 563-0232
Cell: (704) 236-3370
JBoat
05-02-2008 02:16 PM
Fast Forward
0
10-28-2002 11:43 AM
Fast Forward
2
10-15-2002 09:25 AM
G-Force
08-09-2002 02:47 PM
markmastrangelo
1
06-02-2002 06:59 PM
