-   Checkmate (https://www.offshoreonly.com/forums/checkmate-53/)
-   -   What Prop to run 270 Convincor (https://www.offshoreonly.com/forums/checkmate/266065-what-prop-run-270-convincor.html)
BIGBREW 12-04-2011 04:46 PM
Originally Posted by dagah2x (Post 3563330)
I think the 24 is where its at, I could only pull a stock 26 5000 rpms, my 280 is only about a foot bigger but ive got you by a good 100hp.
we cant be having that........just ordered a supercharger!!
BIGBREW 12-16-2011 11:42 PM
still think i may try the 26, its not going to cost me any thing, if it works it works, if it does not it didnt cost me a penny, cant hurt to try
HiPerf2000 12-17-2011 01:33 AM
I had a 253 and ran a hydromotive. i tested everything from 3 blades to 5 blades, and the hydro was the best prop for the boat. i had 575hp and ran a 26p.
BIGBREW 12-17-2011 11:13 PM
i only have 425hp, but when i ran the boat i was getting to the rev limiter before i was wide open, mind you it was the first and last time i ran the boat for the year, so i will not know more till next spring, a friend of mine has a 4 blade 26p i can try for nothing so i guess ill give it a go, worst case scenario i change a couple props, not a big deal..
Moparcrazy.com 12-20-2011 04:56 PM
I am going through the same issue. Im repowering and will be at 700-750HP. Any suggesstions?
