raised motors up....need 28p choppers....
raised my engines up...the prop shaft centerline is now 1.5 inches above the bottomof the hull in font of each engine respectively. huge improvement across the board. i need some 28p choppers to bring the rpms down a bit and get better cruise speed. i also think that my top speed will be better as well. i can hi tthe rev limiter easily now. water pressure is good and the engine temps are the same as before. bout 150 at wo throttle.
anybody have a set of 28 p choppers????
