Go Back  Offshoreonly.com > Owners Forum > Chris Craft
Lower Trim Setting for Alphas on a Stinger 260 >
Old 05-11-2007 | 05:25 PM
Default Lower Trim Setting for Alphas on a Stinger 260
Hi,
I have a 1986 Stinger 260. I was looking at my drives today and noticed that the starboard drive goes down further than the port drive. It got me wondering, just how far down should each drive go. Also, how do I adjust this?
Thanks Much!
Cheers,
Chris
chriscorso is offline
Old 05-12-2007 | 07:05 PM
Chriscorso, I have the same boat and the same problem. I havent found anyone that can answer that question yet. If I get an answer I will certainly post it here.
msel9669 is offline
Old 05-14-2007 | 12:58 AM
Check to see if you have any slop/play in you outdrive collar. the pins ( top & bottom ) wear some and may cause it to drop a little more than the other.
gbcoker is offline
Old 05-14-2007 | 05:41 AM
psmith's Avatar
psmith
I've never noticed that , I'll have to check mine......
psmith is offline
Old 05-15-2007 | 11:26 AM
my 260 is the same way. I never really noticed it that much until I put a tie bar between the two drives. I had it to the shop last winter to have the gimbal brg's, bellows and trim senders done. They went over the whole assembly and said they were in good shape... So??? If anyone finds something out. Please post it.
HuronRiverRat is offline
Old 05-15-2007 | 12:32 PM
I forget the measurement, its in the book somewhere, on alphas theres two senders, one on each side of the gimble, ones the trim sender the other is a trim limit switch, playing with the limit switch might fiw t., when you trim up untill it stops (not trailer position) do they stop at the same place??
phragle is offline
Old 05-15-2007 | 04:18 PM
Trimming up(not the trailer setting), they seem to stop at the same place...only the lower setting is different. Kind of strange...but I guess once I am out on the water, I adjust them anyhow so it doesn't make much difference.
Thanks For the Info.!
Cheers,
Chris
Javelin
Chris Craft
0
06-28-2008 05:18 PM
point92mach
Chris Craft
0
08-20-2007 01:01 PM
psmith
Chris Craft
3
08-27-2006 02:23 PM
ENGINESPLUS
Chris Craft
1
06-29-2006 11:38 AM
ENGINESPLUS
Chris Craft
35
01-16-2006 11:56 PM
