Go Back  Offshoreonly.com > Owners Forum > Chris Craft
Chris Cat prop rotation >
Old 05-11-2010 | 12:51 AM
Katdrvr's Avatar
Default Chris Cat prop rotation
Just curious how other Chris Cat's are spinner the props. I am spinning mine out but think I am going to switch to spinning in. I have five's on boxes, can't remember the x I think it is about 2.5 inches. Really starts to hop above 90 and doesn't stop.
mike
Katdrvr is offline
Old 05-12-2010 | 03:25 PM
Spinning out provides more stability in turns, spinning in will get you a couple more MPH, as far as the hop goes well not sure if it will help.. But from what I remember reading the hop is a balance/air packing issue and wont go away till about 105 to 109 mph depending on lay up type...
Do a search on here for Chris Cat and you will find a ton of info....
bigo181979 is offline
Old 05-12-2010 | 05:43 PM
Katdrvr's Avatar
Thanks for the info. My hop does not go away, I have been past 115 on radar and still hoping.
Katdrvr is offline
Old 05-12-2010 | 06:39 PM
Option B is hit up american offshore and talk to them about their tunnel tab. I think I would rather run a tunnel tab then turn in due to all the bad things I have heard about turning in....
Old 05-16-2010 | 03:05 PM
Katdrvr's Avatar
I have a tunnel tab designed, just haven't found the time to make it.
Katdrvr is offline
