Go Back  Offshoreonly.com > Owners Forum > Chris Craft
Thru Hull Exhaust >
Thru Hull Exhaust
Thru Hull Exhaust
Old 05-22-2010 | 06:03 PM
Default Thru Hull Exhaust
Hi All,
I have a Chris Craft Limited 225 with a 305 OMC. I'm looking to change things up a little this year with out spending a fortune by installing thru hull. Does anyone have any suggestion or input on what they have done? Any input would be great. Thanks
Browny0386 is offline
Old 05-24-2010 | 09:05 AM
Question
Originally Posted by Browny0386
Hi All,
How much is not a fortune?
I mean that with all respect.
Remove your elbows at the exhaust manifolds, cap off your y pipe with rubber sewer pipe caps and buy some stainless steel tips from your performance cataloge and some exhaust 4" rubber hose run the exhaust straight out the back is the cheapest! LOOK AND SEE IF YOU HAVE ENOUGH TRANSOM HEIGHT TO DO OUT THE TRANSOM EXHAUST! (Guessing you doing the work 300 bucks!? BARROWING THE 4 1/8" HOLE SAW!)
Goes up from there!
JR
EASY WAKE is offline
