Go Back  Offshoreonly.com > Owners Forum > Chris Craft
Chris cat fuel capacity? >
Old 07-22-2017 | 04:02 PM
jeff32's Avatar
Default Chris cat fuel capacity?
i just opened the rear seat and there are 2 separate fuel tank underneath... sooooo small its like the ones in a small fishing aluminum 12 feet boat!!!
it looks like they are only 12 gallons capacity tank each when i try to read the old unreadable stickers on them!!! I feel like only 24 gal total for a twin engine boat is just.... not enough?
is there another tank hidden somewhere? What are the usual total fuel capacity of those old resin bucket?
thanks!
jeff32 is offline
Old 07-22-2017 | 10:20 PM
northernoffshore's Avatar
mine had 2 50 gals. ..100 total
northernoffshore is offline
Old 07-23-2017 | 03:27 PM
Mine was 100 per site total 200gal.
now they are modified smaller 65gal per site
to get more cabin size. Also tank's are now ready
for ethanol usage.
shootitup is offline
Old 07-23-2017 | 09:22 PM
jeff32's Avatar
Where is the main tank? Underneath the floor in the tunnel?
jeff32 is offline
Old 07-24-2017 | 01:49 AM
Mine cc cockpit has three front seats side by side.
in middle are steering wheel / driver seat.
driver seat is on tunnel left and right seats are on
Pontoon side's. Tanks are underneath left and right
seats (in pontoons). No tank in tunnel line.
Old 08-01-2017 | 11:20 PM
jeff32's Avatar
Will look for them where you stated! Thanks!
jeff32 is offline
Old 08-02-2017 | 07:45 AM
tanks are in the sponsons from rear bulk head in bilge to the step down in cockpit, you should be able to access the senders and pick up tubea under the rear bench seat
J. Hordubay is offline
Old 11-07-2018 | 08:03 PM
jeff32's Avatar
started taking them out this week... capacity is not written on the tanks... but found 114 gal total on internet specs... wonder whats the range at cruising speed... must be around 25-30 gal / hour right? 3 hours max? might even be only 2 hours running 4000-4500 rpm ? wondering if i should re install the 2 small 12 gal extra tank underneath the back seat... what do you guys think?
jeff32 is offline
