painting bolster alum frames
What are the recommended methods to paint the bolster frames? Have a '94 Bullet. This boat is used in saltwater.
Re: painting bolster alum frames
I wouls say go with powder coat. Seat frames take a lot of hard hits, paint would be my last choise.
F;ylow
The frames are clear coated from the factory making and excellant base for paint. Otherwise you will need to get them soda blasted to accept the powdercoat. ($$$ put it the fuel tank) When you go to remove the cushion base you may find some corrosion on the mating surfaces. Also where the frame meets the floor as well. If your picky, you can blast those surfaces ot just wire wheel & treat with alum oxide primer. Ohter than that, scuff pad & go to town with the paint. |
| All times are GMT -5. The time now is 03:30 PM. |
