A little late but better than never >
Old 04-23-2005 | 08:18 PM
RUSSSR1's Avatar
Default Re: A little late but better than never
A peek inside
RUSSSR1 is offline
Old 04-29-2005 | 09:46 PM
RUSSSR1's Avatar
More
Attached Thumbnails A little late but better than never-boat5_0106.jpg   A little late but better than never-boat5_0107.jpg   A little late but better than never-boat5_0126.jpg
RUSSSR1 is offline
Old 04-29-2005 | 09:50 PM
RUSSSR1's Avatar
Number 2 on the starbord side poped a head gasket. sure am glad I found out this way
RUSSSR1 is offline
Old 04-29-2005 | 09:54 PM
RUSSSR1's Avatar
More
Attached Thumbnails A little late but better than never-boat5_0099.jpg   A little late but better than never-boat5_0100.jpg   A little late but better than never-boat5_0131.jpg
RUSSSR1 is offline
Old 04-30-2005 | 06:16 AM
offshoredrillin's Avatar
Why a gear drive for timing? I figured the harmonics from the drives would be hard on that?
offshoredrillin is offline
Old 05-01-2005 | 07:48 PM
Crazyhorse's Avatar
Reinstalling the gear drives wouldn't be my first choice.
Crazyhorse is offline
Old 05-01-2005 | 09:28 PM
MrCIG's Avatar
Charter Member#330
Looks good Russ.
Just a little side note I find it eaier to pull the trans with the motor. Alot less bending over the back of the motor getting those bolts off. you can slide it out with the drives on. But pull the drives before reinstalling them. You need to check the U-Joints anyway
Good catch on the head gasket. Could of been bad.
Mark
MrCIG is offline
Old 05-02-2005 | 08:53 AM
Crazyhorse's Avatar
Originally Posted by MrCIG
good catch on the head gasket. Could of been bad.Mark
When you say bad, do you mean bad like a sunday morning hangoverheadache? Or bad like a broken leg from trying out your kid's snowboard?
Old 05-02-2005 | 09:17 AM
RUSSSR1's Avatar
OK somebody start talking about why gear drive cams are bad.
They have worked perfect for 300 + hrs. What issues do they present???? Thought they were less prone to fail then chains + more accurate.
RUSSSR1 is offline
Old 05-02-2005 | 09:22 AM
RUSSSR1's Avatar
Looks good Russ.
Mark
Yes I see that Mark. That is the way I would do it next time. I do have plans to replace the u-joints. I started to have a small vib at the end of the season when turning that was not there before.
Did you get out on the water for a test run this weekend???
RUSSSR1 is offline
