-   -   Thinking of converting (https://www.offshoreonly.com/forums/cigarette/104724-thinking-converting.html)
baja john 06-03-2005 05:36 PM
I've got a 29 Baja Outlaw with 502's moded that been ripping for the last 3 years. Starting to get the itch to go bigger. I do like the Baja's but from what I've been reading the Cig's that are the same size same power are about 10mph faster. Really interested in the 38 Top Gun. If someone has 1 like a 2002 or 2003 with the hp525's can you please give me a little insight on how the handling, taking the chop and most importantly speed is.
Thanks.
lucky strike 06-03-2005 05:54 PM
Re: Thinking of converting
We have a 2000 F2 Top Gun T/S with 525EFI / XR Drives with 2' Shorties / Stelling Extension boxes. It's not propped right but it runs 90mph @ 5000 RPM. It should run 92-93mph with the right props. A regular '03 or '04 Top Gun T/S with 525EFI's will run 86-87mph. Some say they have seen higher but I haven't seen it.
I don't know where you boat but we run the Atlantic Ocean and the boat will fly over the 3-5's without any effort.
LS JR.
thespy 06-03-2005 08:36 PM
90.....i might have to get back into boating.
RUSSSR1 06-03-2005 11:16 PM
" XR Drives with 2' Shorties " Quote
Damm LS JR thats one hell of a high X there. What are you doing making Cig's first air boat? :D :D :D
lucky strike 06-03-2005 11:20 PM
& Sportmaster lowers :drink:
LS JR.
baja john 06-04-2005 03:16 AM
That's some pretty impressive #'s. So crazy how a boat that is 38' long is faster then my 29 with almost equal power. I was close on buying a 40 Outlaw with hp900sc's but found out the maintainance on em is too much. They need to be rebuilt every 50-100 hrs. Could of got a good deal on it but I think gonna wait till the end of the season and try to find a Top Gun for a good price. Need something different up here, I'm from Vancouver B.C.
baja john 06-09-2005 02:04 PM
Does the Gun have 2 gas tanks?? Do you have to manually switch them???
lucky strike 06-09-2005 02:06 PM
Yes, a TWIN STEP TOP GUN has (2) 110 gallon tanks
LS JR.
EvilTwin 06-09-2005 03:39 PM
LS JR.
But each motor draws from their own tank. No switching. If one runs out there is a lever so you can draw from one tank to help you get home. My 2002 38 TG with the 575's ran 88 on GPS this past weekend with full load of gear and fuel.
GLH 06-09-2005 05:22 PM
I can vouch for all that is said here.
When I was on it, it was propped for speed and needed skills to get on plane .... but it was a rocket. Five guys on it, flat water cannot remember the fuel but that thing bumped the low nineties anyway.
Impressive boat.
baja john 06-10-2005 05:22 PM
Does that mean you have to fill each tank seperatly??
WildWarrior 06-11-2005 05:20 AM
There is a filler cap on both sides of my Gun, you must fill them both, at least on my 97 that's the case!
baja john 06-11-2005 02:48 PM
How about the newer 1's??
baja john 06-12-2005 03:15 AM
With the newer Top Guns do you have to fill up the tanks seperatly?? Like 2002 & up.
BillR 06-12-2005 06:57 AM
On my '02 Gun; the tanks are filled seperatly.
