What Power to Pick? >
What Power to Pick?
What Power to Pick?
Old 02-14-2006 | 12:56 PM
LostCowboy's Avatar
Default What Power to Pick?
I'm about to order a new ride and would appreciate your ideas on the power choice.
Boat: 39 Cig
Goal: 100mph+ in fresh water @ 650' above sea level.
I've been running 525's w/ XR's and enjoy the hassle free set-up but... I must reach the century mark.
From what I understand, 700-750 HP will get me there. With that I could run XR drives. But I guess my question is this, I would like to go with the Merc 850 or 1075 w/ #6 but wonder about the maintenance? I'm no mechanic.
How many hours will these motors go before they need to be rebuilt?
How do the #6 drives handle verses the XR's?
Any comments and/or suggestions would be much appreciated
LostCowboy is offline
Old 02-14-2006 | 01:03 PM
blume's Avatar
Default Re: What Power to Pick?
Boat: 39 Cig
Merc's new 700hp with new drive
blume is offline
Old 02-14-2006 | 01:11 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
You can't go wrong with Richie Zul power in a Lip-Ship boat.
Go for the Zul 750 N/A tunnel ram motors with your choice of drives. A friend has this same setup with Bravo1 XR drives in a 2003 Top Gun, not staggered. He has eaten a couple drives, but the motors are flawless and magnificent works of art.
If you go to VI drives, you will eat some HP up with those transmissions and drives; but your setup will be closer to bulletproof. It all depends on if you want to cross the large chasm between a Bravo boat and a Speedmaster boat. It makes the boat a different class, and the pricetag also shows the difference.
Sydwayz is offline
Old 02-14-2006 | 01:17 PM
LostCowboy's Avatar
Will this be at the Miami show? Haven't heard of a new motor or drive from Merc. Wonder if the 700 is a pumped up 600 or a detuned 850?
Old 02-14-2006 | 01:23 PM
Tazz's Avatar
850's with #6's is the way to go.
Tazz is offline
Old 02-14-2006 | 01:28 PM
blume's Avatar
pumped up 600, there is a thread in General D. about it.
blume is offline
Old 02-14-2006 | 01:29 PM
LostCowboy's Avatar
Do you know how many hours I can expect from the 850's before a rebuild? I've been told 50 and I've been told 100. I'm not interested in a 50 hour motor, 100+ would be OK.
Old 02-14-2006 | 01:36 PM
44MTI's Avatar
Yes, there will be a new 700(Pumped up 600) with a new drive.
The 850 should be a 100-150 hr motor. Then just a top end. Everyone I know, including Skip from Cig, has gotten over 100hr on their 1075, and then just a top end.So the 850 should just go up from there.
44MTI is offline
Old 02-14-2006 | 02:58 PM
BLee's Avatar
Charter Mod
Like 42MTI said, you should get 150 or more hours out of the 850sci. Pair that with a #6 and it's a bulletproof package.
BLee is offline
Old 02-14-2006 | 04:16 PM
Tbonepmp's Avatar
The Senior Charter Member #1070
Stay with Merc power...
Regards
(What you see, is what you get!)
"Live every day to it's fullest for you give a day of your life to it."
Tbonepmp is offline
