-   -   hatch cover upholstery (https://www.offshoreonly.com/forums/cigarette/124973-hatch-cover-upholstery.html)
stevesxm 03-15-2006 04:07 PM
can someone tell me how the upholtery is attached to the engine hatch cover on a top gun ?
chewy1955 03-16-2006 05:34 AM
Re: hatch cover upholstery
That's a good question. Mine needs a litle attention too so I'll be lookin for the answer.
dreamer 03-16-2006 08:08 AM
undo screw from under hatch remove then redo!!!
since we r on the subject i have for sale a vinyl hatch cover for when ur docked or rafted... better than laying down towels... has cig logo
for sale best offer
will post pics and put in swap shop
lakeluvr 03-16-2006 08:48 AM
dreamer, is correct. The normal engine hatch on a TG is a piece of wood covered with foam then the material. It is fastened on to the fiberglass shell with some lag bolts from the bottom, once the lag bolts are removed the wood will come right off. Depending on age and treatment it isn't too uncommon to have some wood damage so be prepared for that. Good luck.
John
chewy1955 03-16-2006 11:36 AM
Where is the "Swap Shop"? I might be interested.
for sale best offer
stevesxm 03-16-2006 01:08 PM
mine has no such bolts. any other suggestions ?
pm me on the hatch cover cover w/ price and photo pls
dreamer 03-16-2006 07:05 PM
2 Attachment(s)
heres the cover
OldSchool 03-16-2006 07:13 PM
What year is it?
stevesxm 03-16-2006 07:50 PM
96
lakeluvr 03-17-2006 08:25 AM
No such bolts? Did you look closely? Some were counter sunk into the fiberglass and not real noticeable. Others I've seen with big heads sticking out so obviously more noticeable.
John
Sean 03-17-2006 09:10 AM
if its got a mirror, you'll need to remove the mirror and the bolts or screws will be behind the mirros
chewy1955 03-17-2006 09:52 AM
How do the mirrors come off? Are they glued? What are they made of?
Sean 03-17-2006 10:21 AM
mine was glued and screwed
