Adding EFI
Old 03-30-2006 | 03:21 PM
Default Adding EFI
I just bought a cafe racer and i have taken the boat out a couple of times. I love the boat. But when i am idling the motors will die on me periodicly. I took it to a mechanic and they tuned the motors up. The y also said that the 502 carborated motors are hard to idle and will load up on you becuase of the cams the mercruiser put in. Would it be worth it to add EFI to these motors? Can someone help me with this problem.
JeffC is offline
Old 03-30-2006 | 03:40 PM
Codered's Avatar
Default Re: Adding EFI
Sorry not buying your mechanics reasoning.
Codered is offline
Old 03-30-2006 | 05:42 PM
lucky strike's Avatar
Ck the timing !
lucky strike is offline
Old 03-30-2006 | 06:26 PM
ratman's Avatar
time to look for a good mechanic not efi
ratman is offline
Old 04-01-2006 | 11:50 AM
Time to find a new mechanic.
There are plenty of carbureted engines out there that will idle all day long without dieing. Even engines that have much more radical camshafts,
RumRunner is offline
Old 04-01-2006 | 05:22 PM
I have idled my 502 carborated motors for 15 years at 600 rpm and they never stalled. I really question the knowledge of this mechanic.I really feel the stock cam is very conservitive.
27 MAGNUM is offline
Old 04-03-2006 | 01:36 AM
ratman's Avatar
im running the biggest hyd roller crane makes in my 577's they idle @ 800 in gear and never stall, and im running 1050 dominators! with the mild cams your running it should have no issues idling @ 600 without ever mising a beat
ratman is offline
Old 04-03-2006 | 05:33 PM
Thanks for the input guys, I think i need to find someone that knows how to setup the carbs right.
JeffC is offline
Old 04-03-2006 | 06:57 PM
ratman's Avatar
jeff keep in mind there are also good and bad carb guys, one of my engines would load up and die swapped carbs and the problem followed the carb. took it to 2 shops still had the same problem, found a good ole boy dirttrack engine builder, he found the problem within 1 minute without taking anything apart. engine idled perfect when i put the carb back on the next day. i took him the other to go thru for good measure. when he did the first carb he said "go try it if it works like it should come back and pay me"...whens the last time that happened to anyone.
ratman is offline
Old 04-03-2006 | 06:59 PM
ratman's Avatar
btw his name is george pils he owns southern style racing engines in st pete fl, as honest a guy as you will find!
ratman is offline
