-   -   Cigarette Top gun leaking oil caps?? (https://www.offshoreonly.com/forums/cigarette/138063-cigarette-top-gun-leaking-oil-caps.html)
tonypo8 08-16-2006 10:10 AM
I have a top gun and I am having trouble with my drive oil and trim oil caps leaking. Has anyone had this problem. I have the "best" caps and have tried new ones still with no luck.
mjb 08-18-2006 10:57 AM
Re: Cigarette Top gun leaking oil caps??
I have the same problem with the caps on my drive oil bottles. Can't keep a clean bilge. Teague advertises "leak proof" caps. I wonder if they really work....I'm thinking of buying a couple. Has anyone had experience with these Teague caps??
BillR 08-18-2006 12:18 PM
It's likely the reservoir itself is leaking. They all seem to develop leaks around the middle seam. Check that and I'll bet you find your leak.
BLee 08-18-2006 12:52 PM
Exactly. The reservior is cheap hard plastic that will crack along the seam after time. I always hoped Mercury would remedy this, but they never did. Buying new reservoirs is probably the only fix, but they'll more than likely break again.
tonypo8 08-18-2006 01:36 PM
Mine is definetly leaking from the top of the breathable cap. Im not sure what to do. Maybe I'll try those teague caps. If anyone has them let me know.
30 outlaw 2005 08-28-2006 01:10 PM
I had the same problem with all 4 of my caps. I picked up a set from Fred at trick and no more leak and a clean bilge. There worth the money.
ActiveFun 08-28-2006 08:59 PM
Originally Posted by TRICK
"Leak Proof" caps are available in billet aluminum or plastic. I've had good luck with both.
http://www.trickmarine.net/productde...?productid=991
http://www.trickmarine.net/productde...?productid=211
Exactly. This is not limited to Cigarettes!! Every factory trim pump has this problem..
tonypo8 08-29-2006 02:18 PM
Thanks a lot I appreciate the info.
