Cig Battery ??? >
Cig Battery ???
Cig Battery ???
Old 09-07-2006 | 04:32 PM
thisistank's Avatar
Default Re: Cig Battery ???
[QUOTE=OldSchool]
Here's what you do Tank. Put on your "reading" glasses and get down on the floor. Lift the door to access the battery switches. Read what it says. It is small print....but that's what it said on my Bullet and TG.
Craig
QUOTE]
minor details! I don't pay attention to that sh!t. Just turn the key and go baby!
thisistank is offline
Old 09-07-2006 | 08:49 PM
baronmarine's Avatar
[QUOTE=thisistank]
Craig
QUOTE]
tank
i like our style.
todd
baronmarine is offline
Old 09-07-2006 | 10:48 PM
thisistank's Avatar
Originally Posted by baronmarine
tank
i like our style.
todd
Old 09-08-2006 | 05:48 AM
cig1988's Avatar
Originally Posted by Von Bongo
Let me know when you figure it out, my gun has the same 3 battery set up.
I run them on 1 and 1 and they correspond to the port and startboard engines but I am not sure which battery is which and I have no idea what the 3rd one does
We started to track it down last winter and lost interest. Batteries stay charged and everything works so I've kind of ignored it.
I'm pulling out the 2 monster batterys that belong in a semi. The boat's been sitting for 5 years and 1 of the 2 actually start bot engines. When I ran a volt meter with switches on 1 & 1 I cranked both engines & they drew from the port side. All cables are on that single battery. The '89 I had was set up with 3 batt's. Looking at this last night it looks like several holes in the stringer were for the battery mounts. Some rocket scientist decided to install these truck batt's for an unknown reason. If all goes well today I'll be splashing Saturday.
I'll post back with my findings for the curious.
Stan
cig1988 is offline
Old 09-08-2006 | 11:55 AM
OldSchool's Avatar
Good luck Stan!!!
OldSchool is offline
Old 09-08-2006 | 12:09 PM
CigDaze's Avatar
Here you go, Tank.
CigDaze is offline
Old 09-08-2006 | 02:24 PM
thisistank's Avatar
Originally Posted by CigDaze
Here you go, Tank.
Ahhhh, see! Mine doesn't have that writting on it.
Uh, by the way, I see that your switches are on "both"!
Old 09-08-2006 | 03:40 PM
CigDaze's Avatar
Ya, that was one of those days.....
CigDaze is offline
Old 09-09-2006 | 06:16 AM
cig1988's Avatar
I'd really like to meet the person that wired this boat for 2 batt's. Would a freaking nightmare. # batts belong in this boat! I installed the starboard batt no problem. That has 2 +'s and 1 -. Now the port (not including the charger) has 1 + 3 large -'s and a ton of small -'s. I hook everything up and used a post adapter to accept all the grounds.
In the switch panel here's as follow's;
Starboard switch on 1, starboard engine draws from starboard batt.
Port switch on 2 draws from port side batt.
I would imagine you have 2 batt switches & they should both be on "1". Am I missing something ?
cig1988 is offline
Old 09-10-2006 | 09:57 PM
H20 Toie's Avatar
Mine doesn't have the writing either. i always put them on both.
if you put them both on 1 doesn't that mean that they are only running on one battery? i would think that one should be on 1 and the other on 2 or am i missing something?
H20 Toie is offline
