Re: 35 Playboy Speeds
Originally Posted by h20 toie
:d
talk with titos who drove all of them....84 tops with 500s must of left the batteries on when trailering... a 525 boat wont do that :D |
Originally Posted by dreamer
i call bullsh!t
talk with titos who drove all of them....84 tops with 500s must of left the batteries on when trailering... a 525 boat wont do that :D Im thinking the same. My Gladiator which is bare bones in race trim only hits 89-90mph with the stock 500efi's |
i call bullsh!t
talk with titos who drove all of them....84 tops with 500s must of left the batteries on when trailering... a 525 boat wont do that :D i was suprized when i saw the recall. but i guarantee you that i never have towed it that fast. But GPS can make mistakes i have no idea when that speed came up. |
There is a local one here with 525's from NM, they said hit 90, I will see if I can get him to post.
I have an 2003 with 525's with stock bravo 4 blade 86-88 depending on gas. Did hit 90 with props form Tres on fumes.
Originally Posted by AIC
I don't have 500's but 525s. On the GPS speedo, 52 MPH@3500 and 62@4000. 86 on the top end.
my 87 cafe runs 50mph on GPS @3600RPM w/496HOs ... I'm feeling pretty good about myself :) although top end is still around 70mph...@4800(have some adjustments to make so i can get full throttle out of it... so i guess that's where the step bottom really shines...getting more air under the boat at higher speeds certainly helps with top end speeds... |
CRB |
Smoke this does have ITS, Not trying to steal your thunder "T", I just know your boat flies!!! :D
My 2001 ran best of 83 on freshwater w/500EFI's. I saw no improvement when using 92 octane. I also switched to 30" labbed bravos and did not pick up any top speed but accleration was much better.
Brad |
Originally Posted by crb76
Gas? Meaning 93 vs 87 or load? What props did you hit 90 with? Are you running ITS Sportmasters?
CRB |
| All times are GMT -5. The time now is 06:05 PM. |
