Top Gun Switch Replacement???
FIERCE ALLEGIANCE
From [email protected] engineer at Carling....Seems to know his chit.
LTIGM54-6S-WH-RC/GN-MWH-XCR1
CUSTOMER: CIGARETTE RACING TEAM (NO PRINT)
DIST: SWITCH CONTROLS
SUPPORT CARD INFORMATION
MWH BRKT W/WEEP HOLES
12V LAMPS
LNP MATERIAL ON ROCKER
NEOPRENE SEAL
12V LAMPS
NEOPRENE SEAL
I forget the name of the switches in my old Formula but it was a company that primarily built electrical parts for the aviation industry. Same deal though. Start with the basic switch and add options along as you go. Gets to be a fairly long and convoluted part number when you're done!!!
FIERCE ALLEGIANCE
Well, still trying to get this...Tres says I have to go with a non lighted version...not happening. Here's what Carling told me...
Jim, The part number you were provided is a special configuration manufactured to meet Cigaratte's requirements. You would need to go to them or an authorized marine distributor to obtain a replacement part. Carling manufactures all products to order and does not carry stock.
You might also try to contact the distributor noted, Wes-Garde, to check if they have any available inventory and would be willing to sell you 1 piece.
Wes-Garde may be contacted at: (800)554-8866
I'll call in the AM.
The top cover will pop off. I replaced all black cover and switched the white face. Any good electronic shop will have them, either branded Carling or private label. The one's I bought were about $11 each. I'll check tomorrow when I stop by. On-Off-On DPDT?
