Weight of a Cafe >
Weight of a Cafe
Weight of a Cafe
Old 02-13-2008 | 09:57 AM
BDiggity's Avatar
Default Weight of a Cafe
This might be the first of many Cig questions for you guys.
Whats a good avg weight for a Cafe w/ fluids, & some gear? Wanting to get an idea for towing & lift size required.
Thanks.
BDiggity is offline
Old 02-13-2008 | 10:55 AM
Sea-Dated's Avatar
The owners manual for mine shows 9000lbs dry. I keep mine on a 14,000lb lift and it holds it great when full of gear and fuel. I would figure at least 12,500lbs or 13,000lbs when loaded up.
Attached Thumbnails Weight of a Cafe-1991-cafe-racer-067.jpg   Weight of a Cafe-1991-cafe-racer-069.jpg   Weight of a Cafe-1991-cafe-racer-070.jpg
Sea-Dated is offline
Old 02-13-2008 | 12:15 PM
seafordguy's Avatar
Thanks.
When you are doing the math, especially for towing purposes, be conservative and realistic. Don't forget all of the other things that probably aren't included in "dry-stock" weight figures that could potentially add weight to the boat - a couple superchargers add a couple hundred pounds, Sea strainers, Extra Batteries, Swim Platform, Hydraulic Steering, Tie Bars, Fuel could add as much as ~1500 pounds, another couple hundred for water, Covers, Anchors, Lines, Bumpers, Extra Set of Props, Tools, Cleaning Supplies, a full decantur set . That is just stuff I can think of on Mine that might add a decent amount of weight to the dry figure. Not to mention a full steel trailer is probably 3000+ pounds; maybe closer to 3500....
That's just what goes through my head when I think about towing.
seafordguy is offline
Old 02-13-2008 | 12:17 PM
Registered User
Thanks.
I keep mine on a 12,500 K lift.
I agree with Sea Dated....guessing about 11 to 12 K average weight with gear.
excalibur27 is offline
Old 02-13-2008 | 01:17 PM
SKRAMER's Avatar
Probable safe with those #s
SKRAMER is offline
Old 02-13-2008 | 01:35 PM
BDiggity's Avatar
Good deal. I was guessing it would need a 12k # lb lift.
BDiggity is offline
Old 02-13-2008 | 09:53 PM
GLH's Avatar
GLH
#9400 from the literature
GLH is offline
Old 02-14-2008 | 08:56 AM
GLH's Avatar
GLH
Here found my pictures now that I am back in the office.
GLH is offline
Old 02-14-2008 | 09:01 AM
With or with out ...... ummm ..... nevermind !!!
LEOPAJM is offline
Old 02-14-2008 | 09:08 AM
seafordguy's Avatar
Neat - Saved, Thanks.
