Top Gun 1995 - HEAD - help needed >
Old 05-07-2008 | 07:10 AM
seafordguy's Avatar
Originally Posted by MickeyBoy
What do you use ?
Can't recall off the top of my head.
I will check next time I pull my cover off.
seafordguy is offline
Old 05-07-2008 | 08:15 AM
SKRAMER's Avatar
This works good.!!
SKRAMER is offline
Old 05-07-2008 | 08:56 AM
Just bought it !!!!
2 gallons !!
Mike
MickeyBoy is offline
Old 05-07-2008 | 09:18 AM
I'll just hope the flush button works ....
that's the only question to know !
the macerator works !
I don't know the flush works too
how do you use it ?? just putting it into the head ?
Old 09-28-2009 | 03:15 PM
Biggus's Avatar
Originally Posted by CIG3
Here are the pages from the Top Gun Manual for Head Operation.
Thanks CIG3, had some questions and found this in the search feature about the head plumbing.
The head in our boat has not been used in years. I was gaining water in the bilge while underway. Turns out I had a bad water inlet sea cock for the head and the holding tank had been removed years ago but the head outlet had never been plugged. She was shipping water into the bilge!
Kurt
Biggus is offline
Old 09-29-2009 | 11:26 PM
seafordguy's Avatar
Kurt
Funny you brought this to the front. I have been chasing a leak in the bilge for most of the time I have had the boat. Pulled engines/drives/transom assemblies and replaced everything.
Finally realized after all that that the toilet was leaking. Fixed the leaking hose only to have the pump start blowing fuse - luckily this thread shows the pump plumbing and I can most likely just replace the Pump and solve the problem.
Thanks...
lucky strike
Cigarette
12
01-23-2006 09:08 PM
Biggus
Cigarette
1
08-29-2005 03:26 PM
drypipetiger
06-16-2005 11:39 AM
lucky strike
3
11-26-2003 06:10 PM
dhlaw
6
04-30-2003 12:43 AM
