Bullet question...dead batteries >
Old 10-14-2008 | 09:13 AM
lakeluvr's Avatar
www.sunriseuph.com
Originally Posted by Clay Washington
Once you get the batteries replaced, you should check your charger. It may be dead.
Good luck!
That's a for sure possibility. I hear it humming which indicates it is on, but apparently it isn't doing anything. And I'll definitely look into it when I finally get it open. Thanks.
lakeluvr is offline
lakeluvr's Avatar
www.sunriseuph.com
Originally Posted by cig1988
Hi John
I would try going to one of the battery switches with either another battery and jumper cables or a portable jumper box. The former owner of my Bullet wired in jumper posts to the + and - lead mounted on the fiberglass tunnel between the bulkhead and switches.
Well there's an interesting suggestion that I hadn't heard of. I'll check that one out. Thanks.
lakeluvr is offline
Old 10-14-2008 | 10:54 AM
gripit's Avatar
Cig 1988,
Would you happen to have a pic of how your Bullet has wired in jumper posts to the + and - lead mounted on the fiberglass tunnel between the bulkhead and switches? That sounds like a great upgrade!
gripit is offline
Old 10-15-2008 | 02:22 AM
carter38's Avatar
John you can use a jump box or charger and go directly to the pump the blue is up and green is down. Just hook up the the positive and negative with box or charger and make you a little jumper wire and its up. Been there before.
carter38 is offline
Old 10-15-2008 | 04:31 AM
cig1988's Avatar
Originally Posted by gripit
Cig 1988,
I'll try to get one this weekend. Evidently the former owner may have had the same problem as John. The post's are on each side with a plastic cap protecting the inevitable.
cig1988 is offline
Old 10-15-2008 | 08:32 AM
klaw's Avatar
Charter Member #139 /Moderator/Platinum Member
dont even mess with jumping power to the solinoid there
There a power and grouond to the pummp red and black hook charger up to those and then put charger in high amperage then iuse switch on dash
I will take some pics to night and lable the terminals for yopu
Kept the Bullet and the condo and joined the cig 20 restoration club.
klaw is offline
Old 10-16-2008 | 05:33 AM
cig1988's Avatar
John
Did you get this to work?
cig1988 is offline
Old 10-16-2008 | 10:48 AM
lakeluvr's Avatar
www.sunriseuph.com
John
Not yet....it was rainy and nasty here yesterday, so will try today. If no luck will take a pic of my unit and post then. Thanks again to all who have commented. That's what makes this such a great site.
lakeluvr is offline
Old 10-19-2008 | 11:21 AM
lakeluvr's Avatar
www.sunriseuph.com
Haven't gotten down to try again as yet. Were you able to take any pics to clarify things for me? Thanks for your help. John
lakeluvr is offline
Old 10-19-2008 | 10:53 PM
Just take a jump box or good battery and run a wire from it directly to the hatch switch behind the dash. I did it several times on my Pantera.
Griff is offline
