Originally Posted by cigracing1
(Post 2793706)
They only built 11 total Firefox's so it can't be 45.
generally its broken down like this CRT24045L586 crt is cigarette racing team 24 length of boat 045 should be production number L not sure 586 is month and year... unless they went with a diff numbering system for the firefox. |
I know where hull one is, or what we belive to be hull one, it was purchased at the NY city boat show in dec of 71 it is a 1972 cig 19 of which 3 were made the first year. The boat doesn't have a HIN stamped in the hull that was not made mandatory til nov of 1972 for the 1973 model year .
the boat was registered in 1972 as a cig 19 in 73 they went to a 20 same boat same mold . According to Brownie that was due to the CG making boats under 20 feet have flotation foam Donzi also moved their hornet 19 to a 20 footer when we pulled it apart for the resto we found written on the foam of the seats from bilt rite interiors cig 19 we had it out at the 20 cig run a few years ago it's all black yellow stripes yellow interior http://i110.photobucket.com/albums/n...g19cushion.jpg http://i110.photobucket.com/albums/n...1005AKcig1.jpg |
Originally Posted by mattyboy
(Post 2911380)
yup cig19 my friend Kenny really nice boat like an old hot rod
5 Attachment(s)
My old boat was one of the first three 1972 Cig 20's.
I found all three and only myself and number three had the original serial number to compare. My was built in July 1972 and his was built in the fall of 1972. Based on this mine was either hull number 2 or number 1. Considering the information on Cig19's boat, would guess that mine was hull #2. Sold it to KLAW this spring. Here are some pics. In one you can see my old green banana boat next to it. :cool: |
(Post 2911380)
the boat was registered in 1972 as a cig 19 in 73 they went to a 20 same boat same mold . According to Brownie that was due to the CG making boats under 20 feet have flotation foam Donzi also moved their hornet 19 to a 20 footer when we pulled it apart for the resto we found written on the foam of the seats from bilt rite interiors cig 19 we had it out at the 20 cig run a few years ago it's all black yellow stripes yellow interior http://i110.photobucket.com/albums/n...g19cushion.jpg http://i110.photobucket.com/albums/n...1005AKcig1.jpg Cool paint scheme. |
I havn't been on the site for a while......but love to talk about my boat just as much as my friend Matty, who helped me do much of the resto work. The black and yellow combination is the original color combination of this hull.
I kept it the same, but replaced the tired looking teak with mahogany. We used Awlgrip paint for top, bottom and the yellow boot stripe. Kenny |
Originally Posted by Cig19
(Post 2914709)
I kept it the same, but replaced the tired looking teak with mahogany. We used Awlgrip paint for top, bottom and the yellow boot stripe. Kenny Kenny , really the only two items that weren't restored to original were the teak which would have needed attenion by now The mahogany looks awesome and the old chris craft exhaust risers which only weighed about 300 lbs so the upgrade to the Stainless Marine risers were also a good call but after that , everything else is the way she left 188th some 37 years ago she looks better now then she ever did, she as aged like a fine wine ;) |
I own #200890978. I was born 2-27-79 so she's a little bit older than i am.
I think I have you guys mom #0
my boat has no hin but has paper work from 1972 and was pulled from a mold with no chine!!!!!!! The chine were screwed to the fresh gell coat glassed over then the bottom was faired and the boats bottom was primed with shiny gray primer... you do not build a boat like this its how you build a prototype and a mold plug. the boat was cut for out drive and jet drive also what you do when making a plug. so it was the first 20 built and built to test the 20 and most likely tested by Don Aronow to set chine position! and was most likely use to make the mold for all the fallowing 20's the wood chine proves it guys.. I will be stripping my bottom and take some cores to prove the way it was built.... kind neat
Originally Posted by tomuchstuff
(Post 3077293)
Originally Posted by JohnnyMarshall
(Post 3077989)
Interesting:eek:, congrats on the new project.:drink:
so the other 1972 boats that were sold with no HIN one was red and one was black from the factory? were they both jet drive's or was one or both an out drive...
the first advertising for the 19's only offered an out drive.... so I'd think one of the first two boats be factory rigged out drive... I'd like to know if cigarette had two molds for the 20 jet and out drive or an insert for a jet boat mold to make it an out drive the normal way of doing things...This may be why the boats were "changed" in the 80's the insert was lost or don was shot and the info on how to use his molds was some what lost, or some one if not don before leaving cig for the last time just re thought it... if this is how it was done the primary mold wold have to be a jet mold as it's larger pick up box can fit an insert to change the style to O/D...... |
she made the mold and sold her babys?
so what happened to the white cigarette 20' that was in the first advertising?
in that first black and wight ad the boat was listed as a 19,7 and offered with an out drive only.... seems to me the boat in the ad had to be built well before any other 19'7 as you must market to sell and the ad ran in 1971... if the other two 19' boats built built before the hin was added and one was black and the other was red neither can be the boat in the advertising..... this may explain why my boat was gel coated white with a silver water line over the red gel coat at the factory..... see I am an art director and do advertising for a living,,, and when you do news paper advertising the only black and wight advertising done today you have to plan on your ad running on a lot of presses you need your ad as light in color as you can get it........ this way you can still read the ad even if the printing runs darker at one press then others.... and if the ad was planed as a black and wight the boat needs to be wight so you can see it..... now I am not saying I have the boat in the ad... but I have a boat that was wight from the factory that was built before the other two 72 cig's as they were both pulled from a production mold......... there were only 3 built with no hin and two sold and the boat in the ad had to be built in 1971 and was white at least over the red gel coat.. LOL |
Having a tough time with mine. Its a 69 28' that was raced production class......That was 1973 (pre-hull #). Brownie is trying to help verify it.... Supposed to be one of 7 made in 69, but we havent verified this yet.
toomuch,
interesting find and a nice project great work :) . does make sense that the plug would be out there. this is what we know about the black and yellow cig 19 that member cig19 here owns. the boat as lived on our lake it's entire life. it left the factory with those colors. the previous owner made no small fact that the boat was purchased fron Don A. off the floor at the NYC boat show the 72 show which at that time was held in the old NY coliseum and would have been dec of 71 for the upcoming 72 model year. the old owner told everyone who would listen about how he shook hands with Don to seal the deal. HIN's became mandatory on any boat produced after NOV of 1972 for the 1973 model year this one has no HIN and no handwritten numbers like used at Donzi when Don was there. Mechanics who went to get the boat after the purchase recall how the boat looked like it was a rush job sort of ruff around the edges. Probably rushed to get it ready for the show circuit. the boat laid in storage for quite some time and had sunk at one time or another. Cig 19 bought it and the boat was restored to original condition with the exception of stainless marine exhaust risers over the old chris craft logs. paint was used instead of gel for maint reasons. and the original motor was gone thru. chris craft 330 hp small block chevy volvo 270 outdrive ( corvette motor) I am not a motor head but this summer he burnt a valve in the motor and when the heads were removed they found that the valve seats were brass i think . the shop said that they were not salvageble. Later talking to a friend who knows GM smallblocks those heads were only availbale in 1971. so we know the boat was definetly put together sometime in 71. we are not sure if this is the first one or not, but really just want to know the history of this boat. they are really great little boats . hope that helps also the bottom of this boat is almost exactly the same as a donzi 18 classic in proportion of course it is bigger but the design is very similar. 24 degree Vee, rounded keel , full length outer strakes and short inner strakes that end short of the transom I have pics of the project somewhere i see if I can find them. keep up the great work and keep the info coming , :) |
That lower right picture is right at the entrance to the TNT canal on 135 street. I lived there all through the 1960'S and 70'S
I have hull 18, needs a full redo.
Erik |
Hi all. Hoping this thread can pick back up. Getting ready to put TRS rebuilt Outdrive back on my boat. I would love to have people to tap into!! I bought mine this past July, for my birthday, in NJ. Once the Outdrive is dialed in, then comes paint, upholstery and so on. HIN is 099, January of 1978 and has Lucky Strike and Perfect Match on the engine cover. Been wondering about the first owner, if it was first owned by Phil Meshinsky.
A few weeks ago I purchased a 1984 20' Cig. We are in the process of making some updates/changes to it, but look forward to being on LOTO come spring!
Originally Posted by 36Tango
(Post 4512954)
(Post 2793780)
hmm maybe 4 then..based on the number.
Originally Posted by OldSchool
(Post 4712537)
L is for December....So his boat was built in Dec of 85 and was a 86 model. ;)
Originally Posted by WARPARTY36
(Post 4712608)
Nothing like chiming in 10 years later:party-smiley-048:
(Post 4712608)
| All times are GMT -5. The time now is 04:32 AM. |
