top gun prop size please help!! >
Old 07-15-2009 | 09:07 AM
Default top gun prop size please help!!
Ok, 90 top gun. 23 mirage plus, it planes very nicely at 3000-3200 rpm, it cruises @ 45 mph @ 3700-3800 rpm and 64-67 wot 5300-5350 rpm
Bam is talkin me into a set of 23 revolution 4 blades.
What do you cug guys think? I do have 550hp modified engines so the 5300-5350 rpm I am crankin now is ok by the engine builder!
krazy1 is offline
Old 07-15-2009 | 09:11 AM
seafordguy's Avatar
On my 90 cafe I run 26 4 blade Bravos and estimate I put out a little under 600 hp, and turn them to 5100 or so..... Low to mid 70's in chop.... Mine is not a notched transom.
What drives??
seafordguy is offline
Old 07-15-2009 | 10:12 AM
What drives??
oh ya, TRS
krazy1 is offline
Old 07-15-2009 | 07:35 PM
Zero Patience's Avatar
The Four Blades will be far superior to the props you have.
Zero Patience is offline
Old 07-15-2009 | 07:43 PM
I would go with a 22 pitch BRAVO 1 prop.
if u add a blade u want to drop in pitch or u gonna loose to much RPM !!!!
A 22 bravo 1 should still give u ~ 5200+ !!!!
DareDevil is offline
