-   -   Cafe Racer Prop Set-up (https://www.offshoreonly.com/forums/cigarette/223020-cafe-racer-prop-set-up.html)
ajacobazzi 01-19-2010 03:52 PM
Originally Posted by 4195 (Post 3027227)
Maybe some labbed 3 blades. Many places have demos you could try to get it dialed in. I know by todays standards mid 60's does not seem fast but remember you are driving around with a number 1 on the side of your boat which makes way cooler then most. There are quite a few little things you can do later on to increase speed.(roller rockers,crossovers,exhaust,cam change etc). I am also painting my boat right now, we are going to have to start a thread on all the Cafe's that have been redone. Where is Skramer he should start it.
The place that's working on the boat are actually going to do that........test with different props. I figured that I would do a little research on my own to share with them.
Your right about that! A Cigarette is a Cigarette, at the dock, they're all the same.......well.....you know what I mean. ;)
I can't wait to share all of the photos when the boat is done. I just wish that they'd finish the damn thing already. But, with that said, I'd rather that they took they're time, ya know?
ajacobazzi 01-19-2010 03:58 PM
Originally Posted by PromoProducts-BP (Post 3027247)
February 11-15, so a little less than a month. I'll be visiting then and also for 10 days in March. Hope it works out to catch up. At the very least, I'll wander over to admire the progress if she's still at Hidden Harbour!! I see you live in Jupiter, it the boat headed there when it's completed?
I seriously doubt it'll be ready before the show.
She'll be there.........she damn near a permanent fixture there! LOL! Your welcome to check it out all you'd like.
Yep, she'll be headed up to the Jupiter Pointe Club and Marina once it's completed.
excalibur27 01-19-2010 04:39 PM
Originally Posted by ajacobazzi (Post 3027092)
I have a 1987 Cafe Racer that is in the process of a complete restoration. It would be nice to have 500's, but unfortuantely, I only have stock 400's with TRS's. Can anyone offer any opinion's as to what would be the best prop set-up to maximize her potential?
I was running Hydromotive Quad IV's 25 pitch on TRS drives on my Cafe prior to installing Konrads. I am supposedly pushing 500+ HP and they worked well. After switching to Konrads the "x" dimension went up. The Quad IV's wouldn't fit on the Konrad's spline anyway. Now I use Bravo 26's with good results. I still have the Hydromotive Quad IV's 25 pitch and you are more than welcome to see if they work (or not work) for you. They have a solid hub. Shoot me a PM if you want to try them.
Sick Stinger 01-19-2010 08:26 PM
Skramer what power and speed for you. Hey A a cigs a cig and i like the idea of the redone cafe thread im well on my way right now just keep writing checks but loving the outcome so far keep it up boys.
-Mike
SKRAMER 01-20-2010 06:38 AM
-Mike
502 ci Never dynoed, 600+ hp bravo one drives 77mph with 4 blade 26's. ( @ 5600rpm ) Have seen 79mph with 3 blade 27's. Saw 80.6 mph with 2" shorties ( boat wasn't the same. ) took them off. My brother had a 35 mistress with 440 hp and trs drive it would run 65mph with 3 blade 21's he switched to 4 blade 22's and had the same results.
seafordguy 01-20-2010 07:19 AM
I run wieand 177 blowers on a set of 502's. I estimate is it just shy of 600hp - I run 4 blade 26's. I think with light fuel and in some decent chop it is a 75mph boat. 5100-5200rpm.
Sick Stinger 01-20-2010 07:50 AM
Thanks im shootin for mid 80's trs 540/750 with mirage 3 blade 27's or bravo 4's 26
-Mike
rackster 01-20-2010 08:13 AM
Has anyone tried any Maximus props on these hulls with Bravos? I was thinking that they may help free the hull up.
4195 01-20-2010 08:34 AM
-Mike
Thats some big power Mike! Are you beefing up the trannies and drives?
Sick Stinger 01-20-2010 08:44 AM
10 disk carbon trannies bigger shaft drives vertical shaft that is. 9.8/1 540 331 world heads hydo roller 731 triple spring dart intakes gil 4.5 dry pipes 1150 dom's aero pumps.
-Mike
i have the factory velvet drive 7 disk 72's they will be fresh this weekend clutches seals bearings and paint
