Recommended oil; for 88 Bullet, twin 502 Mrecs
What do you guys recommend for an oil for the midwest, LOTO. Interested in what others use.
Hugh Mills |
Im seriously thinking about running Rotella 15 - 40w in my boat this year... its good enough for the Duramax and I usually run the oil about 7 - 10K miles. That should be equivilant to 4 months of abuse on LOTO.... running 500's w/ trs drives. Ran the 20 - 50w in the beginning, engines idled at 65 psi.... little to high for me. Who else has input ?
Super Charged 502's, Gas, 605hp.
I use Mobile 1 Synthetic 15/50. It was recommended by my engine builder. Change out oil every 10 hours of running time. |
I use the Rotella 15W40.. Probably going to switch to synthetic now that they are broken in. Citgo makes an oil called Mystik for diesels/farm equipment. It is a heavy duty synthetic blend diesel 15W50.
I run Renegade Racing Oil...its a 20w50. I switched last summer and it made my motors start much easier. These old cold natured 454's needed it. Very happy with Syn 20w50 so far.
I use Rotella 15-40
I use valvoline racing 20W-50 in my 502's. Change it about every 25 hours. Boat sees 4k plus rpms about 2 or 3 times a year.
I think I am going to switch to Mobil 1 this year though. |
Originally Posted by seafordguy
(Post 3052440)
Valvoline Racing 20w-50 Syn
I would say all of the above a good choices, personally I run Mobil 1 15w50. I have also used Full Synthetic Rotella 5w40, no complaints with that oil either.
| All times are GMT -5. The time now is 06:04 PM. |
