Crank to crank width >
Old 06-03-2010 | 03:00 PM
Default Crank to crank width
Im buying new headers for the cafe racer and need to know the distance between the two crankshaftsd. since my engines are in the shop, i am unable to go down and make the measurements myself.
any help appreciated!
CafeRacerPTY is offline
Old 06-03-2010 | 05:41 PM
You can get the measurement from the transom assemblies or the drives if they are on. Prop shaft to prop shaft will be the same measurement.
You can also measure from the center of the gimbal rings on the transoms.
TxHawk is offline
Old 06-03-2010 | 05:57 PM
Should be 36 centerline
DareDevil is offline
Old 06-04-2010 | 09:13 AM
thnks
Old 06-11-2010 | 11:52 AM
OldSchool's Avatar
thnks
Dude,
Please don't take advice from someone who is guessing. This is something that you need to measure ON YOUR OWN BOAT!! You can measure from the center of the cranks, the center of the propshafts or even from the flame arrestor nuts....but you have to measure it!
For what it's worth, on my side-by-side Top Gun, the engines are on 34.5 inch centerlines.
OldSchool is offline
Old 06-11-2010 | 02:34 PM
klaw's Avatar
Charter Member #139 /Moderator/Platinum Member
Originally Posted by OldSchool
Dude,
good advice
Kept the Bullet and the condo and joined the cig 20 restoration club.
klaw is offline
Old 06-11-2010 | 04:33 PM
MrCIG's Avatar
Charter Member#330
Dude,
Good point My 85 38 Flat Deck is 35" and a Friends 86 38 Flatdeck is 35.5" NO GUESSING
Mark
MrCIG is offline
Old 06-16-2010 | 08:36 AM
Offshoreracr's Avatar
86 Cafe that came with SSM III's and tall decks: 35"
Offshoreracr is offline
