stainless marine gen 3 or long riser system? >
Old 02-23-2011 | 06:43 PM
Default stainless marine gen 3 or long riser system?
One more question for you guys,should I go with gen 3 system and does it require custom tails or should I use there long riser system motor 540ci n/a about 600hp thnks
park35 is offline
Old 02-24-2011 | 08:51 AM
If you call SM, they'll prolly tell you to use the Gen 2 manifolds and give you more tail pipe info. Theyre really nice people.
kreed is offline
Old 02-24-2011 | 08:55 AM
540...go with GEN III !!!!!
DareDevil is offline
Old 02-24-2011 | 09:30 AM
LAKESIDE RESTORATIONS's Avatar
Lakeside Restorations.com
If nothing else you will need to change all of your thru hull tips to 4.5 or 5" tips, OR run thru transom tails which will also escalate your $$. Reducers would not be recomended as they would only start to choke that tail set up and possibly take up needed space or tail length.. Jamie / Lakeside
www.LakesideRestorations.com 570-639-2628
We Make Fast Toys Faster, Cool Toys Cooler and Old Toys New!.. Performance, Custom & OEM Parts & much MORE![/CENTER]
LAKESIDE RESTORATIONS is offline
