Help with TRS Wireing Harness Location >
Old 03-01-2011 | 07:08 AM
Sick Stinger's Avatar
Brotherhood #1
Default Help with TRS Wireing Harness Location
Hey guys I cant seem to place the Engine wireng harness bracket anywhere on the engine. Non of the holes line up. Does anyone have a pic of the set up or know where this F'n thing goes. Im about to smash it with a hammer and make a custom set of them
-Mike
Sick Stinger is offline
Old 03-01-2011 | 08:55 PM
Sounds familiar, I think my original setup had three stamped steel brackets and I couldn't figure out where they went. Solved it with Hardin's stainless bracket mount. It mounted the cannon plug, relay and circuit breaker. I put the Merc ignition module on top of it, needed a few extra holes drilled. It puts the cannon plug right behind the starboard side cylinder head. I was also able to take out a fistful of the original wiring on each engine.
Randy
bustedbrick is offline
Old 03-02-2011 | 03:20 PM
Brotherhood #1
Haha thanks Busted but Id like to use the Oem set up as it is all wired for the MSD and a few other added gauges in the dash.
-Mike
