More power... But how? >
Old 01-08-2013 | 07:19 AM
eightsecmopar's Avatar
Since you are from Illinois I would recommend calling Bill from Ateco. They are in Northern Illinois. Bill is a super nice guy and very knowledgable, not just going to try and sell you something. I put together my engines and had them dyno them. Bill had given me some suggestions on making more HP and also helped me out with some other problems I was having with temperature. Worth a phone call in my opinion.
eightsecmopar is offline
Old 01-08-2013 | 08:37 AM
Full Force's Avatar
Originally Posted by Rbesola
The blower shop has a 10-71 complete kit specifically for the hp500.the guy i talked to said i can bolt them on and go? Bare minimum i would cam. But stock compression seems pretty high? Thoughts on this?
Intercooled prochargers will make more power..
Full Force is offline
Old 01-08-2013 | 10:40 AM
A 500HP carb motor really is not worth much today. Keep what you have, and improve them. Buying used performance engines is risky if you don't really know what is inside them.
Add some polished blowers, the right cam, serp belt system, nice headers, paint the blocks pretty, and have the valve and intake covers custom painted or wrapped to match the boat. IMO that set up with your drives in a Cig is worth way more than those 500hp carbs.
Adding alum heads or a chiller (or both) will make your engines more reliable at the cruise speed you desire.
4bus is offline
Old 01-08-2013 | 10:43 AM
http://www.whipplesuperchargers.com/...sp?ProdID=1159
12-13k bolt on and go for a pair. staying well in your budget
cant beat them
88bullet is offline
Old 01-08-2013 | 01:43 PM
im pretty much sold on the TBS setup if the compression wont be an issue.$4300 a side complete less carbs and upgrade to a 525 spec cam.Which 525 though? efi or sc? And i talked to ateco at pier 57's open house this spring but i wasnt looking for more at that time. Seem like good people though.
Rbesola is offline
Old 01-08-2013 | 03:38 PM
if your going through the trouble of changing the cam call bob madara at marine kinetics and have him custom grind you a couple. 525 cams arent blower cams
88bullet is offline
Old 01-08-2013 | 03:47 PM
BDiggity's Avatar
Wouldnt the cam specs for a 525sc be a blower cam? i agree tho that a custom one based on specific setup would be best. but i dont know the cost difference between the two.
BDiggity is offline
Old 01-08-2013 | 05:29 PM
my bad.. i meant a 525efi cam isnt a blower cam. a 525sc is a 454... needs more cam for more cubic inch. the little more money for a custom grind for his application and the performance gains vs a off the shelf cam will be well worth the money... whats another 2-300 bucks when your spending 10k
88bullet is offline
Old 01-08-2013 | 05:47 PM
Very good point.Whole reason i'm waiting til next winter is the motors will be out again for rebuilds.400hrs on them now, should be around 550 by next winter so cams are a no brainer with them being apart already.
Rbesola is offline
Old 01-08-2013 | 07:35 PM
Big shaft #4s.id like to cruise 65-70.don't really care about wot.as far as budget it will depend power and platform.probably around 15-20k max.
Is 15-20k for the rebuilds and blowers, for both motors?
Wildman_grafix is offline
