-   -   Mistress step plates...ideas?? (https://www.offshoreonly.com/forums/cigarette/289813-mistress-step-plates-ideas.html)
Full Force 01-07-2013 11:05 PM
I want to do something different with my step plates on my gunnel, right now they are stainless with 4 small strips of teak, I thought about removing them and covering with a simple white gip tape, any other ideas? they are approx 4" wide by 28" long or so..
Full Force 01-07-2013 11:09 PM
ok, maybe 32-36" long... kinda see em in the picture...
http://i36.photobucket.com/albums/e4...g/P7137580.jpg
Sydwayz 01-08-2013 07:48 AM
A buddy bought a boat that was sprayed with bedliner material right at those areas, and it has worn very well (obviously). You might look to see if you can find someone who does colored bedliner spraying in your area. Red and/or black would look great.
Full Force 01-08-2013 08:23 AM
Hmmmmmm that might be pretty cool..
tcwcar 01-08-2013 01:13 PM
I had a plastic shop machine me 2 for my Cig Mystique out of 1/2" by 35" plastic, just remembered I'm on cheap status cant post pics, if you want to see them e mail me at [email protected]
caseyh 01-08-2013 01:36 PM
Doing the purple bed liner for the floor in my bullet.
A pice of plastic with cigarette milled into it with LEDs under it for the night time effect. Or some teak with cig in it.
ItsPeanut 01-08-2013 02:23 PM
Keep it original. Refinish them. I like the older classic look. Just a thought.
Holy Smokes 01-08-2013 02:38 PM
x2 - My old Cig had those as well. The teak strips will slide out and you can scrub the aluminum extrusion, clean the teak and re-insert.
502ss 01-08-2013 02:54 PM
Some aluminum bar stock and a a little time in front of the buffing wheel and you can make somre pretty cheap step plates.
http://i69.photobucket.com/albums/i4...cf35b52374.jpg
http://i69.photobucket.com/albums/i4...790c9f2d59.jpg
http://i69.photobucket.com/albums/i4...b/d315da79.jpg
bwd 01-08-2013 03:17 PM
Pirelli flooring or rolled awlgrip with sand. my .02 Great lookin boat btw
BDiggity 01-08-2013 03:43 PM
i had a company in CA (cant think of name at moment, but is/was a sponsor of site) fab replacement teak trim out of billet for the cabin door. i then had it powder coated. I am now going to do the same for the gunwale plate & also for the rear bench steps.
Eddie Marine makes generic gunwale plates but i didnt like the lengths.
Griff 01-09-2013 02:02 AM
Get some 3/8 white starboard and cut it to size. Then run it on a table saw at only an 1/8 deep to put some traction lines down them.
Chart 01-09-2013 10:31 AM
Starboard (HDPE) is slick stuff, but it machines very easy and nice. If you go to use it in a traction application, like a step plate, make your saw kerfs Griz mentioned 90 degrees to each other. That should reduce the likelihood someone slips and hurts themself or your boat while using HDPE step plates. But it is still going to be slick, especially if it's wet.
J-Bonz 01-09-2013 11:45 PM
I second that
Full Force 01-10-2013 10:49 AM
Originally Posted by J-Bonz (Post 3845660)
I second that
I don't mind them, but I need new teak pieces, couple of mine are broke...or I would just refinish em..
ItsPeanut 01-10-2013 01:53 PM
For a man who at one time or another always has everything to put a boat together you should be able to track down a few teak pieces.
RWS Cigarette 01-10-2013 03:51 PM
Here is the original company that made these step plates, they are still in business but changed from teak to starboard in their products:
MarQuipt
3100 Southwest 10th Street Pompano Beach, FL 33069
(954) 957-8333
www.marquipt.com
If you call them and explain what you have and need they will make them for you, I bought 10 pieces of the teak for mine in 2008 for $88.00 shipped, they slipped right in the channels and the step plates are as new.
Note: add an 1/2" to the length for good measure.
Full Force 01-10-2013 11:44 PM
MarQuipt
(954) 957-8333
www.marquipt.com
WOW! who woulda thought you could still get them!!?? thx
J-Bonz 01-11-2013 08:40 AM
If you dont want teak, I think it would look cool with machined starboard...
Full Force 01-11-2013 04:57 PM
I don't mind the teak, she's a classic!!
Holy Smokes 01-11-2013 11:17 PM
TEAK!..... TEAK!...... TEAK!.....
Keep the classics classic! In fact, if you want it ,I will donate enough to mill replacement pieces of teak. I have plenty for the projects I need.
akaboatman 01-11-2013 11:47 PM
Keep the classics classic! In fact, if you want it ,I will donate the teak. I have plenty for the projects I need.
Keep the teak. Thats why you love your boat. Keep it as is. Artie
Full Force 01-12-2013 08:42 AM
Like I said, I have no issue with the teak, I just want to fix or replace whats there..
