Prop Help 02 ts gun 785 hp side >
Old 03-05-2013 | 12:19 AM
Default Prop Help 02 ts gun 785 hp side
need help where to start on props....old props 32 4 blades massaged by throttle up, great improvements but would still tap the limiter..
1.50 drives
new motors make about 150 more, 785 hp 875 tq
im thinking 34 5 blades any help is appreciated
lotopa.com is offline
Old 03-05-2013 | 09:06 AM
BLee's Avatar
Charter Mod
That would be a good start I'd think?
Man that thing is going to be hell on the drives if you're not real easy with it. Sounds like a mean boat.
BLee is offline
Old 03-05-2013 | 09:25 AM
eddie's Avatar
I've got a set of 32 pitch five blades you can try to see what you need.
eddie is offline
Old 03-05-2013 | 09:53 AM
1.50 drives
What did ya buy?!?!?
Brett
black thunder 46 is offline
Old 03-06-2013 | 12:49 AM
thanks guys, not mine and yeah we have been having the drive concern....originally it was a 575 sc boat then the whipple kit added, had some issues so re did valve train and a basic freshen, work was sub par and created more problems, second engine builder found several issues with head work, injectors to small, and blowers worn out, so the hp wasnt sought after, but never turned down lol....Thanks eddie, i think that will give a good base line to start with, I think it should break 100 mph any body else have any opinions on that?
Old 03-06-2013 | 05:52 AM
Quinlan's Avatar
If its a true 785 100+ should Not be a problem.
Better get the SCXs on order!! Just placed my order--- and I am only 650
or you can just buy the 2 sets of XRs I have now.
Quinlan is offline
Old 03-06-2013 | 09:12 PM
what gear case style are your xr's i have a buddy with a 42 fountain needing a drive but would need the steering to work his in 05 model year
Old 03-06-2013 | 09:16 PM
eddie's Avatar
I've got an XR that will work on the 2005, $4,500 complete.
eddie is offline
