thinking Cigarette
Hi everyone
I would like to get some info from you Cigarette owners. In the past I have only been boating on lakes and I own a 2006 Superboat y2k 30. I like the boat a lot but I am in the mids of moving to the Caribbean and the Water here can get huge compare to the Lakes I have been on. The Superboat is great and can handle what ever I steer it into but its very light and likes to ride on top of the water and that will not work down here. I am looking at buying a 38 Top Gun in the mid to late 90's. Speed is not an issue because I would like to do long distance runs. How would one perform with 496's? and is one year better than another? How big are the fuel tanks and what kind of distance could I cover. I know nothing about Cigarette so any input would be appreciated. |
2 Attachment(s)
Originally Posted by pi75
(Post 3900943)
Hi everyone
They aren't going to be fast with 496's. I would guess upper 60's with that power.
They hold 220 gallons. Personally, I think I can get north of 1MPG when I am cruising, but how much ground you're going to be able to cover is going to depend on your throttle hand. They are heavy so make sure you have the right truck. |
38 Cig
I had a '94 TG and have a lot of time on other 38's as well. From '87 on, pretty much along with the early Top Guns, there is a notch in the transom, this helps get 'cleaner' water to the props. The usual caveats apply, make sure there is no water intrusion in the transoms (not bad work by Cigarette, just some later bad rigging work on used boats by shade tree mechanics). Most had 220 gallons as Seafordguy said. In the early 90's Cig built some carbon fiber guns. Most didn't wrap the stringers all the way over the top so many experienced stringer rot. If a carbon fiber boat is fixed properly it is fine. Bravo boats have a nice CG and are easier to work on plus the parts are still readily available.
There are lots of VERY knowlegable Cig guys on this forum like ThisisTank, BIGGUS, and BLEE; you'll get some great info. |
thanks guys, great info pls. keep it coming.
The more I am learning I am leaning towards a bravo boat. Definitely heavy boats but I don't realy want more than 525's and mid 60s to low 70s is all I need . I also have all the bravo tools so that should keep me in the water down here. Now I just need to find a home for the Y2K. |
Originally Posted by O.C.Barry
(Post 3901566)
(Post 3902383)
The more I am learning I am leaning towards a bravo boat. Definitely heavy boats but I don't realy want more than 525's and mid 60s to low 70s is all I need . I also have all the bravo tools so that should keep me in the water down here. Now I just need to find a home for the Y2K. Going back to your original post - if you want something in the mid-nineties I believe they had stopped putting TRS boats out by then. |
In your new home in the Caribbean, will you be able to store your TG out of the water, or will it have to float in salt water all time? Most of the Islands I've been to don't have the amount of land-based storage we do in the states.
It will live on a covered boat lift
stringer
(Post 3902386)
What part of the boat is more prone to the stringer rot?
zzz
Biggus and kidapache
thanks for the great offers but I need to find a home for the Superboat first. Im just looking for info right now so when the time comes and I see one I like I know what to look for. |
(Post 3902960)
From the trasom forward. I've seen a number of boats where the cockpit floor and part of the cabin floor had to be cut out to get access to repair the stringers.
Cg
Originally Posted by TC G
(Post 3906641)
Wouldn't this be the whole boat?
| All times are GMT -5. The time now is 02:01 PM. |
