One thing leads to another, SixGun >
Old 06-18-2013 | 04:29 PM
Zero Patience's Avatar
Valve springs and grind at 240 hours.
We used a dummy block with our transmission and tailstock to mock up and build new motor mounts. This is a long process to get the alignment tool to slide in / out easily. And keep the engines level side to side.
Zero Patience is offline
Old 06-18-2013 | 06:06 PM
hows the balance of the boat now vs. before.
kvogt is offline
Old 06-18-2013 | 08:22 PM
The boat wanted to hop before with the Kondads, between 40 to 60. It's still the same. You have to drag a little tab (380s) at the neutral level to stop it. After 60 no tab needed. It planes very easy now with little bow rise due to the big negative trim capability of a 6
Attached Thumbnails One thing leads to another, SixGun-image.jpg   One thing leads to another, SixGun-image.jpg
Old 06-20-2013 | 04:58 AM
The engine mounts were difficult, but Bryce and I got thru it. The engines are level side to side, and the 6s slid in the transoms. We had a few discarded mounts we made for the recycle bin.
Old 06-20-2013 | 09:15 AM
Looks great and congrats on the conversion. You will love it. Now you need to get a myco with a drive gaurd to protect your investment. Tommy's engine are the best of the best we have them in our gun and never a problem. Our boats over there at his shop which im sure you saw it. Its the 38 staggered gun.
SkaterMike82 is offline
Old 06-20-2013 | 10:28 AM
mmb
Originally Posted by Zero Patience
916 or 857 depends on which pulley is on top. With the 6 drives some Chief 1550 turbos would be nice.
Nice!! I might build a turbo engine next time with Joe.... He was trying to talk me into it this time!
mmb is offline
Old 06-20-2013 | 01:39 PM
mmb
Did your engines move up or down compared to where they were at with Konrads?
mmb is offline
Old 06-20-2013 | 05:21 PM
They moved up, about 2.75 inches.
I hear you about the drive guard, I built the trailer so I went back to work on it
Attached Thumbnails One thing leads to another, SixGun-image.jpg   One thing leads to another, SixGun-image.jpg   One thing leads to another, SixGun-image.jpg
Old 06-20-2013 | 05:24 PM
One thing leads to another...
Old 06-20-2013 | 07:32 PM
Now it needs a new swim platform to clear the #6s
